Results 1 to 15 of 22
    kierownikszatni's Avatar
    Poland/Germany
    Default Renault Espace IV 3.5V6 Hitachi Hi-ewr20 Immo
    i have problem with Renault Espace IV 3.5 V6. The car won't start after discharge battery. Immo light is on. Steering lock is ok, connection between ECU and UCH too, I can turn ignition on but engine doesn't start. In ecu there is immo problem. Power feeds, Gnd etc are ok. In the eprom the place where should be VIN is empty. Probably there is problem withe eeprom content. Does anyone have eprom for this ecu, or can repair mine? Or maybe the problem is elsewhere? I don't have idea what to do... In the country where I live this car with this engine ( 3.5 V6 from nissan) is very rare so I don't have experience.
    In attachment eprom read from my ecu and photos of ecu.
    Thanks in advance.
    Bllinda's Avatar
    Baltic
    What is a VIN? Do you read UCH95160?
    today
    A topic that interests me
  3. The Following User Says Thank You to Bllinda For This Useful Post:
    kierownikszatni (14th March, 2021)
    Poland/Germany
    Quote Originally Posted by Bllinda View Post
    VF1JK00CB36626550. No I haven't read uch eep. I only checked via clip that vin is ok.
    Bllinda's Avatar
    Baltic
    Please try and report. Read again after syncing.
    today
  6. The Following User Says Thank You to Bllinda For This Useful Post:
    kierownikszatni (15th March, 2021)
    Poland/Germany
    Immo still blocked. Here is the reading after the synchonization attempt. Thanks for help.
  8. #6
    rafal's Avatar
    UK - PL
    here ori file from ecu as you have.............for compare
    need help
    now my goal is to buy xp-005
    who will help?
  9. The Following User Says Thank You to rafal For This Useful Post:
  10. #7
    Poland/Germany
    Quote Originally Posted by rafal View Post
    Thank you very much! Maybe it will help me...
  11. #8
    need you virign file for self learing? post original dump
  12. #9
    Poland/Germany
    Quote Originally Posted by okura View Post
    Yes i need virgin file. File readed from ecu in attachment.
  13. #10
    test and report, pass PM
  14. The Following User Says Thank You to okura For This Useful Post:
    kierownikszatni (16th March, 2021)
  15. #11
    Poland/Germany
    Unfortunately, this solution does not work. The reading after the test is attached.
  16. #12
    code stored again, what you have a problem?
  17. The Following User Says Thank You to okura For This Useful Post:
  18. #13
    Poland/Germany
    Code stored again but vin is empty. Should i write vin manualy or via clip? Immo light is on, engine doesnt start. In ecu immo fault code. Starter works but engine doesn't start. No fault codes in other units.
  19. #14
    Poland/Germany
    Thanks all for your help. I bought ECU from scrap. I virginised it, programed and the car start! The problem was a damaged eeprom dump. Thanks again.
  20. #15
    Bllinda's Avatar
    Baltic
    Uploud donor damp. Thx
    today
  21. The Following User Says Thank You to Bllinda For This Useful Post:
    rafal (17th March, 2021)
