Results 1 to 12 of 12
    Jan 2022
    Default 2011 Maserati Quattroporte PIN code
    Hi all,
    I am working on a 2011 Quattroporte. The vehicle has a flip key where the PCB has damage where the battery would make contact. I am trying to make a new remote flip key for the vehicle. I pulled the EEPROM and Flash data using the IM608. I was able to program a new transponder to the vehicle.
    According to the Autel, the remote functions are programmed separately from the transponder and requires a 5 digit pin code. I opened the EEPROM data using the IM608 and the Tango and the PIN code is not listed.
    Is there a different method of getting the PIN code for the vehicle? Thank you for any help!
    dealer only????
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Far far away
    Where is your files?
    Jan 2022
    I have it on my Autel, on my laptop and on an email. Would you like for me to share it with you?
    lupu_sandu's Avatar
    Far far away
    In general is a good start to post files when asking for help
    Jan 2022
    Oh, I'm pretty new to this forum. It says on here that .bin files are not an acceptable format. I'll zip them and attach.
    Dec 2010
    Ro
    75465,try this pin
    Bllinda's Avatar
    Baltic
    I would try again like 41759 and it is 75465. PM me the ID/SN of the key you have. And check with TMPro ....
    today
    A topic that interests me
    lupu_sandu's Avatar
    Far far away
    Structure is similar as Fiat Stilo so i will bet on @emanuel2010 pin.
  10. The Following User Says Thank You to lupu_sandu For This Useful Post:
    emanuel2010 (5th July, 2022)
  11. #10
    Jan 2022
    Thank you everyone. I will try that PIN in a few days. How did you find the PIN? Specific software or just looking at the bin file in a text editor?
  12. #11
    Jan 2022
    I forgot to update. The PIN 75465 worked. The remote was programmed. Thank you everyone! Is it possible to know what software allowed you to read the PIN?
  13. #12
    Bllinda's Avatar
    Baltic
    There are buttons at the bottom.
    Quote Originally Posted by backpackwedgie View Post
    today
  14. The Following User Says Thank You to Bllinda For This Useful Post:
    emanuel2010 (18th August, 2022)
