Results 1 to 3 of 3
    Moderator
    krazylegz's Avatar
    Mar 2008
    Crowthorne / Sunny South Shields
    Default No internet via ethernet after windows update
    Afternoon all,
    I have a Dell Latitude 3520 (approximately 6months old) running Windows 10pro version 21H2, and since the June update (KB5014699) I have limited internet access via ethernet lead, will work normally for about 1 minute then, Google maps will work, google will show search results but clicking on a search result or other bookmarks I have none will work.
    If I take out the ethernet lead they all work fine, I have tried to uninstall the update but it fails to uninstall.
    I have been on the Dell website and updated any Bios/drivers there was to no avail.
    Does anyone have any ideas on how to sort it other than a system rollback?
    PS3= krazylegz120282
    please read the rules >>>>http://www.digital-kaos.co.uk/forums/f5/forum-rules-2/
    if you're new to forums and want to make your first post please read here>>>>http://www.digital-kaos.co.uk/forums...ul-tips-30279/
    if you like what people say please use the reputation or thanks button, dont just make a post to say thanks
    Feb 2020
    Argentina
    Hello.
    Did you try to roll back the driver from device manager?
    If you are sure that the update you mention caused the problem, try uninstalling it as follows:
    Open PowerShell as administrator and run the command
    wusa /uninstall /kb:5014699
    I hope this helps you.
    Greetings.
    Nov 2022
    Europe
    check the availability of drivers on the hardware manufacturer's website and software tools. Try to install them ...
