Results 1 to 15 of 15
    Oct 2016
    Default CIM clone Opel Astra H PIN code
    could someone help me for the Opel Astra H CIM module PIN
    Valeo 2810502
    GM 93184321
    Manufacturing date 22.03.2017
    Attached original eeprom reading 95160
    Could you confirm if to replace it is enough to copy the 95160 eeprom, the references are exactly the same, attached MCU CIM image.
    Bllinda's Avatar
    May 2010
    Baltic
    No pin code, damp. what is needed .... ?
    Quote Originally Posted by daten View Post
    Valeo 2810502
    GM 93184321
    Manufacturing date 03.30.2009
    This is the current topic for me in 2022.10.
    508 9HD 1.6 HDI_SID807_BR2 ( 19 Faults )
    today
    Subaru Forester 1999 sync. A pair of H44H and F93C46 is required.
    A topic that interests me
  3. The Following User Says Thank You to Bllinda For This Useful Post:
    daten (23rd August, 2022)
    Oct 2016
    Quote Originally Posted by Bllinda View Post
    I want to clone the sim, but first I want to check the pin code, vin data.
    Ninjor s's Avatar
    Aug 2020
    Bcm2
    dump bad readed,unsolder eeprom chip and read again.
    the lesser you use your brain,
    the louder you use your mouth.
  6. The Following User Says Thank You to Ninjor s For This Useful Post:
    budata (23rd August, 2022)
  7. #5
    Oct 2016
    Quote Originally Posted by Ninjor s View Post
    The 95160 eeprom reading is done with the desoldered vvdi prog eeprom programmer.
    Check the eeprom read 95160 from the other CIM unit and they are similar
  8. #6
    budata's Avatar
    Feb 2018
    Bulgaria
    I also think it's a bad read….try again or replace the device...
  9. #7
    Oct 2016
    I don't have the vehicle in my workshop but I managed to communicate with the new cloned CIM with the original data from eeprom 95160 and everything seems to be fine the vin is correct, there is a programmed key, I managed to calibrate the steering angle sensor using the pin that I I provide the owner of the vehicle.
    But I have a fault code
    B3057-00- Security code not programmed
  10. #8
    Ninjor s's Avatar
    Aug 2020
    Bcm2
    reset and program again.
  11. #9
    Oct 2016
    You mean reprogram the pin code?
  12. #10
    Bllinda's Avatar
    May 2010
    Baltic
    Read any of these blocks
    https:/ /sutarta.lt/skelbimai/automobilio-pasas-car-pass-6625443.html
    today
  13. #11
    Ninjor s's Avatar
    Aug 2020
    Bcm2
    .......yes here virgin cim CIM Opel H_EEPROM 95160 Virgin.rar
  14. #12
    Bllinda's Avatar
    May 2010
    Baltic
    What do you think about that ....
    today
  15. #13
    Oct 2016
    Hello
    Thanks to all for the help
    I want to confirm that the cloning has been successful, the engine starts without problem. I don't understand why no calculator can calculate the pin code. I also thought that the reading is bad or the eeprom file is corrupted.
    I hope one day to discover the mystery.
  16. #14
    Bllinda's Avatar
    May 2010
    Baltic
    Hello
    Did the error go away by itself?
    today
  17. #15
    kiszka's Avatar
    Aug 2009
    wystarczy zaprogramować pin nic więcej
    Reality of life :
    1:Never argue with an idiot, he will drag you down to his level and beat you with experience
    2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
    3:Jealousy is a sign of inferiority
    4:Everyone lies
    How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
    If you like to read garbage, don't slow down, just speed up
