Hi excuse my ignorence but i just bought a rs232 null modem 9 pin cable female to female but after reading your sticky am a bit confused. will my one work or do i need another cable. thanks in advance for any help
can any 1 help cant scan chnls no transponders found after flashing with new flash not a clone
hi guys, i tried to install the USB driver but it was a "DRV Remover" I don't know what it has done to my laptop?! Is that what should have been downloaded via that link? How do I know if my laptop has now recognised the cable? thanks
P.S. I bought the cable from Ebay http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=370124907312 and this http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=120343734127
I went into Device Manager and there is nothing for COM Ports, I saw the name of the cable but it says driver not installed so I tried a driver from here - http://www.wiretek.com.cn/download.a...er_lei=windows nothing seems to have happened yet though.
Hi all,
Used the cables and connected my eurovox as shown/described on the diagrams etc, but when I connect it to my pc, the pc is not picking anything up.
Checked my My Computer/Hardware/Device Manager/Ports and they show Prolific USB-to-Serial Comm Port (Comm 8) so it appears to have recognised the Usb to Serial port adaptor, but not the Eurovox (connected to the adaptor (I confirm that it's connected via a straight through Serial RS232 9 Pin Female to Female cable).
If I can't correct this, how can I flash the box?
Can anyone also let me know which udates I need to flash (i.e. do I just need to flash the most recent or do I need to flash earlier updated first?).
Could use a link to the latest flash update.
Thanks all!
is it possible to buy a null modem cable with a male and female connection as my pc has a female 9 pin port
when flashing a pvr 5000 box have you got to have the telewest cables attatched in on he eurovox as well or just the null modem cables from the computer cheers
where do i download the latest firmware for the eurovx ex 1000 sl. Seem to be going round in circles
Take a look here http://www.digital-kaos.co.uk/forums...firmware-9787/
I'm going to order the leads from ebay tonight, I've been meaning to get some for a while but kept putting it off, trouble is that it seems Vermin have rolled the codes today and there's no new Telepest codes on keymaster yet
I have tried to use a usb to RS232 converter uner vista but have had no luck so far. Has anyone else managed to connect to a eurovox 2 with one... (I have no RS232 plug on my laptop.)
Many Thanks ---
SAM
Have you tried installing the drivers for the null modem cable to usb adapter mate?
you can find some here....
Digital Kaos - Downloads - Maplin serial converter
Digital Kaos - Downloads - cheap ebay usb to rs232 cable software
Sometimes a slow gradual approach does more good than a large gesture.
If anybody is trying to get the usb to serial cable to work under vista 64 bit, you can forget about it, coz I tried but in vain. I think it will only work for vista 32 bit and xp of course. If you happen to have vista 64 bit installed (like me) your only option is to run a virtual copy of xp within vista or dual boot your computer. Hope this help.
this is all good im about to try myfirst one
Hi all,
using correct serial null, but laptop on xp pro will not open the port, how do i force the relationship ?
Thx,
digime
