Try test interface without power +12V. If appear "Not plugged into a car", you have bad dump, dump corrupted.
But for sure, please, put here a picture with the other face of PCB
no it doesnt appear this message. here you go other side of PCB
What message appear?
With +12V i understud, appear like in your picture, "interface not found".
Without +12V (with cable in USB, of course)what message appear?
i recieve this instructions from chinese, i will try today and report:
Close the anti-virus software
1.please uninstall software first friend
2.then copy the software to your PC and install it again
3.change your computer time 2013.06.01
4. install the software
5.you can test it again
OK, do that.Beta versions are limited in time.
A topic that interests me
well i tried what little chinese told me. Now i get this messages: not connected to 12V, connected to car
and
it seems that TEST is ok but anyway i cant do nothing with cable
Broken or wrong dump.
or, although unlikely, FTDI defective, but FT232RL defective occur rarely, FT232Bx defective occur more often
Have somebody read dump from chinese 11.11.3 or still nothing?
Will it be possible to share?
BTW There is new Beta 12.10.7
Hi all need some help with my vagcom 805.0 , the cable lets me read controllers separately with out issues , but when I want to do a full scan it does half of it and then throws error up about needing a registered version , it alsp wont let me change any coding now ? the cable was working fine till today , the laptop is not connected to the internet while I use the cable so it has not updated , when I run the test it finds the cable and its says version 1.79 , then I save and go to about and it shows it registered but stops working again ? any help with this? thanks in advance![]()
