Page 297 of 854 FirstFirst ... 197247287292293294295296297298299300301302307347397797 ... LastLast
Results 4,441 to 4,455 of 12803
  1. #4441
    @jacob: led is red, why?
    Must be Green. You power-up the cable? (+12V between pins 16 and 4 OBD2 or plugged in a car).
    If not, that's the problemm.
    And if LED is red when connect at usb, the cable is cheap and bad.
    Few photos with both sides of PCB, good resolution.
    @dadymee: loader is a little programm used for some versions of VCDS.
  2. #4442
    Nov 2015
    Hello User, where can i get a good quality clone cable to use VCDS?
    http://aliexpress.com/item/VAG-15-7-...rchweb201560_9
    Is that a good deal?
    http://www.digital-kaos.co.uk/forums...ight=atmega162
    atmel
  3. #4443
    Feb 2013
    need some opinions..
    In the pictures attached are 2 interfaces (1=old one 2009, 2= 2013) .
    Nr. 2 has STC on pcb, because was "damaged by internet" I had to reflash Atmega to make it work, but without removing STC.
    After first test it looks that it working fine.
    So, is this type of interface(nr. 2) an exception that could be reflashed without removing STC chip? Or it is a matter of until will stop working(without internet " help")?
  4. #4444
    That stc is worthless. You'll be better of without it. It's no exception. There are others cables with stc that got the atmega162 data compromised. And in time the ft232BL won't work ok with that stc on the board.
  5. #4445
    Feb 2013
    I know that STC is worthless... but on the other side of PCB are signs that another STC (or something similar = 10 pads on 2 sides) was removed. See pic...
  6. #4446
    2 kind of "stc protection": like yours and like the other PCB.
    Writing in atmega or in FTDI
  7. The Following User Says Thank You to liviudiaconu For This Useful Post:
    alexm1 (24th November, 2015)
  8. #4447
    Nov 2015
    Hello, where can i buy a HQ Clone for VCDS 15.7.1?
    I know www.sklad66.com, but sklad66 is much expensive.
    Which chipsets use a HQ Clone?
    Where can i see a board layout picture?
    Greetz
    atmel162flasher
  9. #4448
    bravel digital's Avatar
    May 2014
    morocco
    hi guys Can I reflash this vag118 v 908 to 11.11 / 12.12
  10. The Following User Says Thank You to bravel digital For This Useful Post:
    FoxMulder (26th November, 2015)
  11. #4449
  12. The Following User Says Thank You to liviudiaconu For This Useful Post:
    bravel digital (26th November, 2015)
  13. #4450
    Senior Member makadam's Avatar
    Nov 2010
    EUROPE
    I have a problem with 15.7 clone, with Atmega MCP2551 and TJA1050 STC chip inside. Cable work only with K line CAN is not working. I replace MCP2551 and TJA1050 but result was same, CAN not ready. My old 11.3 work perfect! Does anyone have schematic diagram or maybe solution for this problem?
  14. #4451
    Delete few PM, inbox full
    and look what mean search:
    http://www.digital-kaos.co.uk/forums...CDS-EVERYTHING
    Post #10
  15. #4452
    Nov 2010
    EUROPE
    Post #10
    Pm is deleted!
    Sent from my Redmi phone
    We can't help everyone, but... everyone can help someone!
  16. #4453
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello can someone please help with dump for gal for BL tool. My dog ate the gal IC.
  17. #4454
    Nov 2011
    Hey there,
    I have a Chinese Vag11.11 interface, firmware 1.84, FTDI FT232BL, & Atmega 162. It reads and writes to the FTDI any .ept, so it's recognized and I can install any drivers for it.
    The problem is it still shows up unlicensed. I'm not sure if I haven't had the proper .ept, or if the Atmega is damaged, and need to be reflashed. This past .ept I used (VCDSFT232BL.ept, from fantomels "1.VCDS COLLECTION") didn't return to the "this feature needs a registered copy" during auto-scan. It left me with:
    Do I need to reprogram the Atmega for sure? I may just get a new interface since it was only $20, but if I can change the device to work with internet connected, as I've heard, I'm interested in learning.
    I've included pictures of the device below, just in case. Thanks for your time.
  18. #4455
    Rewrite atmega with proper dump and use proper installer.
