Page 333 of 854 FirstFirst ... 233283323328329330331332333334335336337338343383433833 ... LastLast
Results 4,981 to 4,995 of 12803
  1. #4981
    -D-
    It is possible to update this cable
    What can I connect to j2
  2. #4982
    Feb 2016
    Moldova
    Quote Originally Posted by pepeEL View Post
    Ok but not remove from PCB ? Only wire solder to chip on PCB ?
    No need remove. Wires to chip on PCB.
  3. #4983
    Feb 2013
    I do not see Atmega on pics posted above....dumps shared here will work with any chip?
  4. #4984
    Home
    no only with atmega162
  5. #4985
    -D-
    Hi , i play with the solution from kolimer .
    I have a old cable 11.11 with HW 0x44 updated.
    Now i have a error
    what do i wrong
    solution:
    Files are missing in the folder
  6. #4986
    DK Veteran deluss's Avatar
    Jun 2011
    I have update my atmega in cable hw 0x44, but when i try to scan in VCDS craced, with external 12v i see " interface not found", but when i off external 12v and then try to scan i see " inferface found but not pluged to car".
    What i need to do after update atmega (flash and eeprom) ??
    Need also to ftdi ?? (i try to change ftdi with mprog but when i try to prog i see "no interface found".
  7. #4987
    Jan 2016
    deluss install the driver for USB Interface and then try to locate it with mprog
  8. #4988
    Jun 2011
    I install this drivers: CDM-2.08.28-WHQL-Certified, and still have problem with MProg.
    http://imgur.com/a/Oxo8G
  9. #4989
    Home
    Quote Originally Posted by deluss View Post
    it's not problem with ftdi, reflash atmega again and check fuses
    edit// ok, you have erased ftdi flash again
  10. #4990
    Jan 2016
    install deluss last FT_Prog 3.3.80
    and do the same as at the video3.avi
    https://youtu.be/HsDqpbKsK58
  11. #4991
    Jun 2011
    I try do the same like you on film but i have error. I think i have wrong file or my cable need one more time to change atmega.
    http://imgur.com/a/ApKeA
    //edit I repair this problem. I change in my .xml chip numer from FT232R to FT232/245BM
    When i test cabel in vcds, i have on every click different message.
    https://ibb.co/gnkwNa
    https://ibb.co/esY5Fv
    https://ibb.co/kBPZ8F
  12. #4992
    Home
  13. #4993
    @Dellus: You have FT232BM/BL or FT232R?
    Because in your images i see FT232B with FA24... not so good.
    I suppose you not use correct file.
  14. #4994
    Jun 2011
    I open my cabel and inside is FT232B.
    So what i need to repair my vcds? with file is good ? I need reprog atmega one more time ?
  15. #4995
    Oct 2008
    ok downloaded 17.1.3v2 and have hooked up my 0x46 via the pin header to usbasp, and extreme burner sees the chip. how do I go about flashing it? sorry need a step by step.
