Results 1 to 9 of 9
    Nov 2016
    South africa
    Default VCDS FTDI USBART ERROR
    Hi All,
    I have Vcds cables that need to be reprogrammed, i have purchased them off ebay but they do not work, when you plug it in the pc it states usb not found.
    I know that it needs to be flashed or it wasnt programmed by the supplier. I have 12 of these and i would like to get them working as it is stock thats just getting wasted.
    Is there a way of programming and can someone please pin point me in the right direction as to what needs to be done step by step?
    Thank you in advance.
    Jul 2016
    Vilnius
    Please share the pictures of the PCB board of the cables.
    If the PCBs are different, then share all the versions you have
    * MK100
    Nov 2016
    South africa
    xoom's Avatar
    Ylakiai
    many photos of one side )) none of them showing uC ) but i guess its ATMega162.. you need to reprogram them
    Nov 2016
    South africa
    Quote Originally Posted by xoom View Post
    Hi Bro, thank you, how do i program it? what tools/programs are needed :-)
    May 2016
    Kaunas
    Quote Originally Posted by Veex89 View Post
    Are You kidding? Google does not work for You?
    If You are not able to find information - You will not repair it.
    Good luck.
    Trstenik - Thun
    if you are lucky enough you will not need any programmer,just PC and VCDS
    Dec 2014
    PL
    If you have ATMEGA 162, try this.
    http://obd2-diag.blogspot.com/2017/0...al.html?q=vcds
    and
    http://www.digital-kaos.co.uk/forums...light=vag+vcds
    Nov 2016
    South africa
    Thanks Mario. You are very helpful. I will follow this guide and let you know how it goes
    Sent from my SM-A520F using Tapatalk
