Page 1 of 4 1234 LastLast
Results 1 to 15 of 54
    Feb 2019
    Default CORSA-D not starting
    I hope someone can help me as I am really stuck. I have a 2008 Corsa 1.4i sport 2-door. The car originally died while driving. It was taken to an auto electrician which I believe did more damage than good.
    In any case I am now stuck with it. Originally the car did not crank at all and the engine check light flashed. I have discovered and fixed the following:
    - Bad connection to BCM
    - Got the security key for the car from the manufacturer. This key did not work on the IPC. I had to open the IPC and dump the EEPROM to obtain the correct key
    - Reset BCM, ECM and IPC and re synced all to a point where the engine check light does not flash anymore and the engine cranks
    - Opened the ECU for inspection. No water damage and now broken wires any visual damage
    - Used an oscilloscope to diagnose the electrical interface on the high speed CAN bus. There is no issue with the CAN electrical waveform.
    The car still does not start and the outstanding issues are:
    - The ECU relay does not come on. The relay works and if bypassed the ECU voltage shows correctly on the diagnostics
    - The fuel relay never comes on. With OP-COM this can be manually switched on, but the relay does not engaged. Like the ECU relay, this can also be bypassed in which case the pump works.
    - The following error codes are still shown: U2107-71 Invalid signal from BCM; B3057-00 Security code not programmed; U2107-71 Invalid data from BCM; B3902-00 wrong immobiliser identifier received; U2105-00 Invalid data from ECM; Wrong environment identifier received IPC
    Any help would be greatly appreciated.
    unu's Avatar
    Oct 2010
    EUROPE
    what engine ecu have you there ?
    looking onto your DTC's (error codes are still shown: U2107-71 Invalid signal from BCM; B3057-00 Security code not programmed; U2107-71 Invalid data from BCM; B3902-00 wrong immobiliser identifier received; U2105-00 Invalid data from ECM; Wrong environment identifier received IPC )
    I believe you didn't reprogramm correctly these modules.
    Reset all and do it again.
    Good luck !
    Feb 2019
    The IPC, BCM and ECU can be reset.
    The IPC and BCM can also be reprogrammed (I cant remember if the ECU can also be reprogrammed), through there menus
    The Immobiliser can also then program the BCM and ECU.
    I have read somewhere that both the ECU and BCM should not be reset at the same time.
    Do you know what is the sequence of reprogramming everything? Should one reset them in a specific sequence and then reprogram them in a certain sequence?
    Bllinda's Avatar
    May 2010
    Baltic
    I think it will be very difficult to do it with op-com ....
    This is the current topic for me in 2022.10.
    508 9HD 1.6 HDI_SID807_BR2 ( 19 Faults )
    today
    Subaru Forester 1999 sync. A pair of H44H and F93C46 is required.
    A topic that interests me
    Feb 2019
    Why?
    What is the alternative?
    Bllinda's Avatar
    May 2010
    Baltic
    It's easier with techII ....
    today
    Apr 2016
    uk
    Try reset and reprogram all units including airbag ECU.one by one...
    Reprogram keys at last.
    If you will still have error for keys program a new one.
    Sent from my MI MAX 3 using Tapatalk
    Feb 2019
    Good morning.
    So last night I did all the combinations I can think of. At this stage all the units are reset and reprogrammed. All units share the same security key (this was not the case before).
    I was very optimistic about this, but it did not work.
    I still have an issue. U2107-71 Invalid data from BCM and invalid signal from BCM. This must be some configuration issue since I can successfully talk to the BCM, ECU, IPC and SDM.
    When I try to start it, there are some sensor codes also like the throttle position sensor and the throttle body circuit.
    How do I determine if I need to replace the BCU?
    Apr 2016
    uk
    After reset bcm you need to wait 10-15mins with ignition off..
    Then reprogram bcm and others
    Bllinda's Avatar
    May 2010
    Baltic
    Look .... ....
    Quote Originally Posted by omglol View Post
    Let's first start with info about the car:
    Opel Corsa D, make year 2009
    engine: Z14XEP, 66kW, 1364 ccm
    VIN: W0L0SDL0896046608
    Quote Originally Posted by perovuk View Post
    opcom is ok for this car if u have pin code,try this metod
    1reset ipc
    2 reset bcm
    3 reprogramme original key
    4 reset airbag module
    5 turned off ignition for 30 seconds
    6 programme the ipc
    7 programme the bcm
    8 programme the airbag module
    9 read and clear all fault codes
    10 ignition off 30 seconds
    11 START CAR
    Quote Originally Posted by Liteace View Post
    Any help. Can pins on ECU's
    Engine, pins 11 & 43
    Abs pins 14, 15, 26, 27
    Airbag contol unit, pins 35 & 36
    Radio, pins 9 & 10
    Info display, pins 17, 18, 19, 20, 22, 23, 25
    Park pilot, pin 6
    today
  11. #11
    Feb 2019
    Thank you I will try this. IS the 10-15 min delay after resting the BCM applicable?
  12. #12
    Feb 2019
    Morning. I tried everything last night. I cannot get past the errors. It does not matter what sequence I use nothing works.
  13. #13
    rafal's Avatar
    Jul 2010
    UK - PL
    Looks like ecu damaged.
    need help
    now my goal is to buy xp-005
    who will help?
  14. #14
    Feb 2019
    Why the ECU? I would rather think the BCM is damaged
  15. #15
    kadett90's Avatar
    Mar 2017
    Are these codes all in present?
