Please share the pictures of the PCB board of the cables.
If the PCBs are different, then share all the versions you have
Hi All,
I have Vcds cables that need to be reprogrammed, i have purchased them off ebay but they do not work, when you plug it in the pc it states usb not found.
I know that it needs to be flashed or it wasnt programmed by the supplier. I have 12 of these and i would like to get them working as it is stock thats just getting wasted.
Is there a way of programming and can someone please pin point me in the right direction as to what needs to be done step by step?
Thank you in advance.
I can calculate ABS module codings for:
* Continental/Teves MK60EC1 and MK60;
* TRW systems in Passat B6 / B7 / CC /Tiguan;
* MK100;
* Bosch ABS8.2, ABS9.0 and ESP8.2, ESP9.0;
* EBC 460 (UP!, Mii, Rapid, CitiGo, Fabia, Toledo, etc) New!
* ... and other VW/Audi/Seat/Skoda modules.I can assist with repairing \/CDS interfaces.
many photos of one side )) none of them showing uC ) but i guess its ATMega162.. you need to reprogram them
If you have ATMEGA 162, try this.
http://obd2-diag.blogspot.com/2017/0...al.html?q=vcds
and
http://www.digital-kaos.co.uk/forums...light=vag+vcds
