Hey mate, check this out:
ELM - Simple GAL Programmer
EEProm, PIC and GAL Programmer
Welcome to GALBlast
They are not that quickier to build... but I never found one simplier![]()
My cable is with FT232BL, Atmega162
also need to check GAL and input transistors
I have with UPA, Atmel 162 programmed
I have read Fuse bits and progremmed
Yes I have 12V in my Car,
I have vag old who works in the same Auto
When you more detail from Fuse Bits have can you send?
Hi guys
i need help with pin code for passat 2005 model.here is the cluster picture.when i use my sbb *(clone) it says pin code unavilable.i have sbb,xprog-m,ad90 for tools.how ca i read the pin code using the above tools?
thanks in advance
Papiti56 (14th January, 2018)
I have 2 interfaces with FT232BL inside, one of them after programming it with different dumps: 704, 805, 908, 10.6 says Interface not Found. Dumps 100% working tested on other interfaces and works fine but not with this cable, What could be wrong. STC chip and other components removed.
The second interface same as above after connecting it to computer is not recognize at all. I mean there is nothing in Device Manager, no Unknown Device or Serial nothing at all. After connecting it into USB port nothing happened, no sound that something was connected to computer no reaction at all. I change USB cable on interface but still to same, no idea what could be wrong?
for the first one - check the GAL / AFT device!
atb
Keep going people, this is awesome
