Page 12 of 40 FirstFirst ... 2789101112131415161722 ... LastLast
Results 166 to 180 of 592
Thread: MPPS Repair
  1. #166
    vanya86's Avatar
    Mar 2010
    Ljubljana
    Quote Originally Posted by pantadeo View Post
    Programmer for C8051F340 .
    I know this company, i was in their office, 20? is their programmer.
    And i think you are not allowed to share their work!!!!!!!
  2. #167
    ecutuners's Avatar
    Apr 2011
    United Kingdom
    that device does not support c8051f340
    Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
    ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
    EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
    DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
    Professional Engine Software Development
  3. #168
    DK Veteran mishu_b's Avatar
    Jul 2009
    Land of Choice!
    there is needed for programming uC a special one.
    you can find it on SiliconLabs web site.
    atb
  4. #169
    Jul 2010
    South Africa
    I have problem with my MPPS clone. It is 234 chinese clone.
    It was working perfectly, then i tried to install v4 software and now it doesnt work.
    I re-installed V3.0.2.37 but it doesnt want to give me ECU ID, Read or write.
    Serial number still displays as ....234
    Im getting an error 1 & error 13 when connected.
    Is there a way to fix this (I bought another one already)
  5. #170
    Jul 2009
    Land of Choice!
    error 1 = interface has not plug in to USB port
    error 13 = interface has a different fw than software version required.
    it it can be unlocked for which fw version you would like to have. (v3, v4, v5)
    atb
  6. #171
    gomarota's Avatar
    Sep 2009
    hi mates, i bought yesterday an c8051f340 with 5.0.1.10 fw inside, i will get the debugger from silabs and see if its working, i wish is not protected, i talked with a company for read protected mcus and it cost 1400USD, so i think its better to buy a working dump
    For read/write onboard:
    usb debugger - microcontroller
    pin4 - c2d
    pin7 - c2ck
    pin2.3.9 - gnd
    LOVE DK!
  7. #172
    ecutuners's Avatar
    Apr 2011
    United Kingdom
    Quote Originally Posted by gomarota View Post
    pin4 - c2d
    pin7 - c2ck
    pin2.3.9 - gnd
    You can try to read but it but you will fail, soon as mcu is programmed it is locked, even after hw update in mpps the lock byte is protected, good luck you will need it
    buy the dump or more mcu's is cheaper way.
    Danny
  8. #173
    Jun 2009
    Porto
    Quote Originally Posted by ecutuners View Post
    Danny
    Anyone who sells or can point me to a seller of a programmed mcu for latest version is welcome to PM me
  9. #174
    DK Veteran stevan's Avatar
    Dec 2008
    Bosnia
    BeeProg can program silab ICP,anyone try it?
  10. #175
    DK Veteran rsibiza's Avatar
    Wink
    Quote Originally Posted by stevan View Post
    There are beeprog ISP programmers which are able to write these ones...
  11. #176
    tehnosoftex's Avatar
    Romania
    I did, it works very well, only 4 whires
  12. #177
    Dec 2008
    Bosnia
    Thanks for reply.I see in Beeprog that for RST check must add 2 resistor and condensator,so i will try to reflash
  13. #178
    Romania
    No need to add anything. Just uncheck some options from device options. I power up the mcu from beeprog , only need to connect 4 wires - + C2D and C2Ck
  14. #179
    Jan 2010
    Must to be connected at pins 7, 11, 13 and 14 from c8051f340 ?
  15. #180
    Romania
    Quote Originally Posted by laszlo View Post
    7, 10, 13, 14
