Yes, mpps showed 12,6V
I take the optican with the same voltage and its worked!
What`s a print screen?
Driver ist 6.0.1.0
Date 17.11.2009
Amt-Cartech Ltd
it was thought to be patching the patched from scary
will check if it works vice versa or with (later) originals.
Procedure:
1. Install MPPS V5.0.1.10
2. Run Patch MPPS V5.0.1.10 Patch
3. Put in the usb (from interface)and run FirmwareUpdate.Exe then MppsUpdate.exe
4. Finaly interface works
So, if i understand properly, at point 2, must use your patch, right?
And it works with baned serial...
yes, correct
atb
@lo lo oo1981 - it is working for any serial. tested with nice results.
atb
so,no matter what i do,have no sn.anymoore it showed 0000000.think the interface are bricked.
best regards
Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
Professional Engine Software Development
I installed my mpps and put usb, open the folder, click mpps.exe and when open in video result error: 101 what is this errorthe operation I have do perfectly. I have a nootebook Toshiba whit XP and first is win7 but I dont like win7 and installed XP any help??? for mee. Tanksssssssssss
My mpps show my good sn with 5.0.1.10 but i have problem with ecu not found k and can .Hou can i go back to 3.0.7???When i plug mpps with 3.0.7 sn is 00000
Windows XpSp 3 mpps alu
A: you need to reflash with 3.0.2.7 dump.
Q: I have a tool on my hands that shows when I'm trying to read ID to CAN - "Internal hardware error" - anyone else faced with such error?
atb
