Results 1 to 11 of 11
    DK Veteran chiptorque's Avatar
    Nov 2010
    Default Pin-code Opel Corsa C
    hello I need pin-code of the vin no. if alguine can help me? thanks ...
    Woloxcf6834267821
    Dec 2009
    Do you have any dump? For example dash.
    Nov 2010
    no, my friend only ECU 0261207962 ME 7.6...
    Mar 2009
    Quote Originally Posted by chiptorque View Post
    post it
    regards
    Nov 2010
    I do not understand ...
    Mar 2010
    Opcom can read corsa c security code!
    Buy one, it's cheap and usefull interface...
    Mar 2009
    if you have ecu motor from your car can you read the dump from ecu and post it here? after we will help you .
    understand?
    DK Veteran kasim_izmir's Avatar
    turkey / izmir
    Woloxcf6834267821
    hello friend
    you are must be use products similar (same is the like link), or you can get security code from opel dealer..
    BTW , you can get security code from dashboard , select instrument>eeprom menu > read security code , if your ecu from same car..
    ( NASRATECH
    SMOK ,)
    BR
    kasim
    Nov 2010
    thanks...i probe
    kugglefischer's Avatar
    Jun 2010
    In an Ecu
    Quote Originally Posted by kasim_izmir View Post
    hello friend
    ( NASRATECH
    SMOK ,)
    BR
    kasim
    Hello Kasim.....
    Maybe you can help me out?
    im looking for a wiring diagram so that i can power up and reset an opel 0261207962 z12xe bosch ecu on the bench using opcom...can you please give that to me, if you have it? and in which plug...with the details? is really appreciate that my freind....
    K
    The difference between men and boyz...Is the price of there Toyz.
    LEACHERS.....DONT KEEP ASKING FOR PASSWORDS
    DONT FORGET TO PRESS THE THANK YOU BUTTON IF MY WORK HELPED YOU....
  11. #11
    Nov 2011
    HI CAN SOMONE PLEASE HELP. I NEED TO CODE KEYS FOR MY 2001 OPEL CORSA. I NEED THE PIN CODE
    VIN NO. ADMRE80BK1Z997533
    IMMO ID. EB 24418925 0896 2195 2201
    KEY NO. S1740
    THANKS
