can anyone confirm if the tspanel server is down, iv just reflashed my 800 and it says no internet connection or server down when i try to update the pannel, the box is connected to the net ok.
Faster than Faster
you can update it thru sim 2 addons in tspanel
it was pissing about the other day...then came back on.....but can confirm it is down again
thanks for confirming.
Faster than Faster
i am having the same problem, i have tried to download mgcamd for sim2 server via tspanel which it does but when it installs i can find it anywhere. Hope tspanel servers come back on line soon been three days so far.
Is it still down?I get the same error with no Addons download failure,No internet connection or server down
Yes the internet it is working.The router is a huawei hg655b and it is working fine.
I'ved downloaded some addons and there are no problems execpt the ts panel.
Thanks in advance!
Was down for me aswell yesterday and found it strange??
Firstly thought it was an internet problem till i saw this thread.
Back to manually installing .ipk's for a while methinks
Freck
Just checked now and can confirm its down.
Regards
Seen a post elsewhere yesterday, they are working on it and it will be back ASAP.
It's not all down, you can still reach addons from other panels.
According to mfaraj57, four out of five addon servers are still online. However the Tunisiasat server is under maintenance but should be back soon.
can you explain what this means. currently trying to download crossepg via tspanel. is this possible currently or do i need to chill for a while
Chill for a bit or manually install the IPK version you require.
