65 years and still learning
don't you mean "why do YOU have a pic of charlie chaplin ?" at least get it worded correctly mate
@ honestly mate ....did you think that was charlie chaplin.........ya FOOL
extremely amusing ...
BUT STILL OFF TOPIC
some folk (TULGEYWOODMAN) just dont know when to stop being a fudd
please mate you are just a f**ckin nuisance aint ya
take Fallens advice FFS mate
Today is the Tomorrow you worried about yesterday ......Was it worth it ?![]()
hi
at the end of every topic it become the uk friends each other problem decession topic....why so because 85% of user of this forum is from uk...its my opnion...
Hi. I am kind of new to carprog. I have a quick question for someone who used carprog before. Do i need to have good srs dump(file) to overwrite the bad one or can i just clear crash data with carprog without having to search for good file who knows where?
The genuine article has always had a counter. The hacking will have been done on 4.01, the latest version available at the time it was hacked.
In the hack will have been a counter stopper. So version 4.00 is just as likley to trigger the counter as any other version that has not been modified to work on the copies.
ANDRUSHKA
You need a good dump from the crashed srs to repair the srs module, so you can't just use a blank file) . The carprog will look for certain things in the dump before it will even load.
Its a pain sometimes, the other anoying thing is it won't repair a file from memory. So if someone on DK wants you to repair a dump they have posted you have to download that dump into an eeprom, repair it then read it back to file.
I have had it where the srs module isn't listed but one with virtualy the same number is listed. So I think I will try to repair with the simular part number ( used to do it all the time in the early days on clio's ). Now when yo load the dump you want to experiment with it will not proceed because it knows its not the correct dump.
yes carprog does it for you... well on the ones it has in its db.
Sent from my ViewPad7 using Tapatalk 2
As stated by someone, yes if its in the database, but as also stated , if the dump is trashed, then you need a similar dump to start with.
So its a good idea to start building your own personal airbag database with crash and clears, but make sure you are meticulous about the numbers because the variants. so besides the obvious numbers, title any letter variations and also the exact model etc.
A pain at the time, but as I learned to my cost, the same as dash datasets, the more info, the better in the future when you need them.
When using carprog, you can save and or view the dataset before and after the repair
Well, the man who thinks he discovered alternating current [but didnt] still looks like Charlie Chaplin to me! [although at one time they lived in address`s less than 3 miles apart]
personal insults contravene the forum rules and are not nice.
Someone once gave me sound advice...........Be careful what you say, unless you know who it is you are saying it to!
may all your troubles be little ones.......![]()
*OFF TOPIC*
on topic
so is everyone who has a clone quite happy with the opel ecu software working fine ?
off topic
OH DEAR ...A THREAT ?
ime absolutely shitting myself here![]()
maybe that advice should be heeded in this case "BY YOURSELF PALL"
please mate do yourself a big favour eh
and "get yerself to ~~~~" !!!!
....... obviously not quick enough eh mate![]()
The opel ecu software on the original works fine for me
