Page 1 of 2 12 LastLast
Results 1 to 15 of 27
    V.I.P. Member mickydibble's Avatar
    Nov 2008
    modsvilla
    Default Htc desire hd stuck!!
    NYC desire stuck on boot screen ,I have took batt out,men card sim also put back in still same any ideas? Cheers micky
    Jun 2012
    enter recovery mode and refalsh it :P
    Canker_Canison's Avatar
    May 2010
    12th Level of Hell
    Try a factory reset first.
    Hold volume down & press the power button.
    If the boot screen stays on, use the vol buttons to scroll down to 'Clear Data' & select (power button I think)
    Canker
    [COLOR=Green]
    Nov 2008
    modsvilla
    Quote Originally Posted by Canker_Canison View Post
    I unlocked the phone by code,and is now on giffgaff,will doing a reset lose my unlock?
    Nov 2008
    modsvilla
    Neither worked guys unresponsive in the menu back to same?
    Nov 2008
    modsvilla
    Downloaded restore configuration image I think!?,formatted mem card dropped on image as zip because it said don't change nothing much happened format card again then put raw img on,tried to run that on phone bootloader no joy I'm stuck. Help!!
    May 2010
    12th Level of Hell
    Give HappyHighlander a buzz via PM. he has more knowledge about Rooting & software flashing than most of us on here.
    But if it still has warranty on it you should look at sending it back for repair. Warranty lasts 2 years in the EU
    Canker
    [COLOR=Green]
    Nov 2008
    modsvilla
    Cheers ,well it was a phone that was on contract and I ~~~~ed it off and unlocked to giffgaff and was ok for a while it's my partners not sure if anything happened for it to stick on boot but will probes pm happy later when back from asda cheers pal
    happy_highlander's Avatar
    Aug 2010
    Quote Originally Posted by mickydibble View Post
    I'm not exactly sure if it's hboot your stuck in but if it is all your questions will be answered in the link I've pm'd you mate. It is specific to the desire hd so will give you better advice than I can.
    Nov 2008
    modsvilla
    Happy , the phone came back on by it bloody self ?? Anyway seems ok for now
  11. #11
    Aug 2010
    Good for now them mate, just make sure you have a backup of everything you need incase you get locked out for good
  12. #12
    Nov 2008
    modsvilla
    Quote Originally Posted by happy_highlander View Post
    done it again happy, the bashtard !!
    just come on i should back up, but it asks for update is this safe
  13. #13
    Aug 2010
    I haven't got a clue m8 but I would assume it is, I don't think they can do a network locked update unless it is the sim from the original network that's in it, by rights it should only do a standard software update
  14. #14
    Nov 2008
    modsvilla
    You were right pal seem to have updated fine and re installing stuff cheers. For now it works
  15. #15
    Aug 2010
    Good m8 that should have installed the new bootloaders that will replace the ones that were a bit iffy. Has you android verson number changed ????
