Page 26 of 38 FirstFirst ... 16212223242526272829303136 ... LastLast
Results 376 to 390 of 569
  1. #376
    Sep 2009
    Quote Originally Posted by omglol View Post
    By "unlock signal wire" you mean disconnect signal wire?
    Yes, m8 ,he means exactly to disconnect the a 3-wire connector under the seat. .... Seams))
    Every day, every hour I like. Still alive.
  2. #377
    Sep 2009
    I need a little help. I've read a lot of threads here on DK, but I can't find specific answer/instructions.
    How exactly do I disable passanger seat occupancy sensor on Mercedes C-class (W203), make year 2004? Thanks!
    Hereis another way.Quicker and easier.
    You need password free tool. Here in somethread have been discussed , to enter inside Special Functions menue.And disable AKSE there...... And ofcoz pull out 3-wire cable.
  3. #378
    Nov 2009
    After coding you must disconnect seat occupancy sensor.
  4. #379
    smayer's Avatar
    Jan 2012
    If seat sensor have plug just. disconnect, if don't have dedicated plug you have 3 wires, Gnd +5 and signal, cut signal wire.
  5. #380
    omglol's Avatar
    Jan 2009
    Europe
    Password free tool? Say what?
  6. #381
    diagnoza_auto2000's Avatar
    Jul 2010
    Sibiu
    Always you need to disconect the cable
  7. #382
    Sep 2009
    Passfree tool. Some mods to be able to go inside special functions menu.
  8. #383
    Dec 2009
    Prussia
    Quote Originally Posted by kfprint View Post
    Ive heard there is a way in dev to reset the upper speedlimit to 100mph in 906 sprinter 2007 without a sdk code
    currently this is set to 90kph the vehicle was once a taxi and wont allow a higher value to be set just a lower value. I need it to be reset to 112kph
    anyone know the procedure?
    I need to remove speed limiter on 2008 sprinter.
    Does anyone know exact procedure with star dev. please?
  9. #384
    Moderator
    PremierD's Avatar
    Jun 2009
    The OP mate Qrius...
  10. #385
    Jun 2010
    Default Hi
    i want to know please if is possible to reset 7G the VGS2 or VGS3 with dev mode?
    thanks in advance
  11. #386
    Dec 2009
    Prussia
    Quote Originally Posted by danrad View Post
    thanks in advance
    no way with dev.
    buy abrites update....expensive.....but only way.
  12. #387
    Is it possible possible to change vin in automatic transmission and motor ecu with dev mode?
  13. #388
    Jun 2010
    Quote Originally Posted by james44000 View Post
    what is the model and year?
  14. #389
    Nov 2012
    thanks that is helpful
  15. #390
    Sep 2012
    Apollo Beach, Florida
    Quote Originally Posted by ponstar View Post
    With that approach, your membership could be one of the shortest on record!!
    Be patient
