Results 1 to 3 of 3
Hybrid View
    Dec 2008
    Default F3 ccam.dfg offine
    Hi guys having a problem with my f3 box lines have been entered ok but I have to manually activate the cccam.dfg file every time after its been powered off. Even though the green tick is by it the only way is if I switch from Ethernet to wifi and back it will connect then fine.
    Any help will be much appreciated
    Jase
    Junior Member parricull's Avatar
    Mar 2011
    Lancashire
    Quote Originally Posted by jasewinds View Post
    Jase
    Try a different firmware bud, this is a common problem on older firmware , tbh im unsure if they rectified the issue in the new software.
    I couldn't wait for success, so I went ahead without it.
    Dec 2008
    Well I downloaded the latest firmware off here and channel list and its still the same wont connect unless I manually change to wifi then back again
