Sorry to ask this but what are you trying to do with your wii mate?
I have checked your Drive and it looks like it should be compatible with your wii. Rod how many partitions are there on your drive? Is 320 the full capacity or part of it?
it is full, i think it is only 1 partitions, how can i check it?
if i try to install this cIOS38 Rev.12 in my wii and if it is already in it is that going to brick my wii?
Ok mate try to install cIOS36_rev9 again.
Digital Kaos - Downloads - cIOS36_rev9-Installer
If rev9 do works!!! DON'T try and install rev10 but if it doesn't then install rev10.
Digital Kaos - Downloads - cIOS36_rev10-Installer
If that doesn't work then install this one:
Digital Kaos - Downloads - cIOS36_rev12-Installer
If that still don't work then install this latest one:
http://www.digital-kaos.co.uk/forums...aller-wad-719/
Hopefully by installing 1 the above will sort out your problems and your headache mate![]()
Do u know if there is another way to format the usb hd to wbfs? I installed the last one and it is not working haha, ill give up i cant do it any more tks for your help and the wast of your time hahaha.
well i am trying to get the usb loader. i have homebrew browser but can get everything to work by the apps folder. Never before used a wad thing and dont no what to install 4 it.
oh yeah the other guys usb was 320gb mine is only a 32gb memory stick might that be the problem
This is for being able to play copied games on a usb instead of discs, but when are you able to play copied games from a disc on a wii.
Last edited by undercoverjamil; 3rd June, 2009 at 06:38 PM. Reason: was same as top comment for some reason
Don't give up just yet matey, I will always be here to help and don't worry you haven't wasted my time (much).
Let start from the beginning:
1. Can you please tell me how did you go about formating the USB drive?
2. Are you using WBFS Manager to format it or wii to format it?
Your USB shouldn't be a problem mate and if you go to the very first page everything is there to get you going in regard with installing USBLoader.
But to be able to play copied games on your wii go to this page and again everything is there.
http://www.digital-kaos.co.uk/forums...like-me-20545/
Hope this help.
ive deleted everything in my usb, and formated it for fat32, ive used the WBFS Manager to format it and ive put some games in there, but when i connect it in the wii and go to usb loader the usb loader says that is not formatted and ask if i would like to format it, when i click on yes come a screen saying that the usb cant be formatted, so the usb loader is detecting the usb but not that it is formatted for wbfs, ive tryed every thing but dosent work, tks for your help mate.
hi mate ive just tryed a flash usb of 4gb and it works perfect and ive done everything ive done in the anotherone, sop i think this one of 320gb doesent work on usb loader
tks yumraaj for your help, every time i opned my usb in my pc it open 2 one is the hdd with 298gb and another one thet is a cd drive password do you think thatv is the problem if yes how can i delete it, or if i want to buy a new one wich one is better freecom, western digital or maxtor?
tks
It looks like you have 2 partitions on your drive and if the main partition was converted to CD Drive that is why you cant format it mate. Try the fat32formatter and use initialize the whole drive, it might or might not let you format it, try and see.
Let me explain this to you.
Let just say you buy a brand new Drive e.g 1 TB and you partition it to create 300 gb from it. So you will end up with a main drive of 700 gb and a Virtual drive of 300 gb.
So if you decide to use the virtual drive with the usb loader, it wont work!!! instead you will have to use the 700 gb.
The answer is to create a partition of 700 gb and leave the main drive to 300 gb. Which mean your main drive will be 300 gb and a virtual drive of 700 gb. The use WBFS Manager to format the 300 gb and away you go.
Hope you understand What I said!!!
Anyway for the best drive I would use this list please dont buy seagate at any cost.
USB Devices Compatibility List - WikiTemp
Good luck matey
