Results 1 to 15 of 6927
Hybrid View
    Dec 2009
    Quote Originally Posted by cotymoto View Post
    Where is the defect? Engine, cluster.remove battery negative 3 min and read with vag com and clear dtc.
    Enviado desde mi LT30p usando Tapatalk 2
    Hi, The Fault code its in the 25-immo module
    01-Engine and 17-Cluster are fine, no DTS stored.
    Ok , thanks i?ll remove the battery and check.
    Regards
    Aug 2009
    Quote Originally Posted by eltiobarbas View Post
    Regards
    Normal because you do mileage by obd and it cant erase all tool playing obd you will get this error
    solution is by programer for not get this error
