Results 1 to 14 of 14
    Nov 2011
    Default TOYOTA RAV 4 / 1998 / add key to immobox
    i have toyota RAV4 / 1997 / immo box = 89780-42030 with 93LC66
    Engine does crank, but NOT start.
    The 2 original keys are broke, also NOT possible to read transponder with TMPRO2
    I have 3e key, buy from dealer, which i can perfect READ with Tmpro2 and gives me :
    Transponder recognized as Texas fixed
    ID 4C - JMA TP02/TP07
    TIRIS Data: 7E 84 0A 17 0B 00 00 00 00 E6 2D 7E
    Can someone add this key into the 93LC66 data from the immo-box please
    93C66 ORI ELNEC.rar
    richard27's Avatar
    Aug 2011
    you try this file image
    ​information sharing
  3. The Following User Says Thank You to richard27 For This Useful Post:
    CARPARTS (11th December, 2014)
    Nov 2011
    thank you, but your file is not working .
    Engine cranks, want start and shut off, just like before.... so immo is still inside
    someone has solution ?
    gwee's Avatar
    Dec 2012
    unknown
    original dump already have your new dealer key, how come??
  6. #5
    bram380's Avatar
    Aug 2009
    Indonesia +628153111774
  7. The Following User Says Thank You to bram380 For This Useful Post:
  8. #6
    Nov 2011
    Quote Originally Posted by gwee View Post
    ???? thats new to me, they bring the car like that with the 3 keys. I didn't touched nothing yet !
    But if this is true , then the engine should work, but it doesnt... so maybe other problem
    Tell me, Gwee, is there maybe any procedure to respect after programming the 93lc66 ? or just put immo box and start ?
    @ Bram, i will test your dump now...
  9. #7
    gwee's Avatar
    Dec 2012
    unknown
    Quote Originally Posted by CARPARTS View Post
    key is in the dump but added wrongly, someone tried before you and corrupted the dump
    bram's dump should work
  10. The Following User Says Thank You to gwee For This Useful Post:
  11. #8
    Nov 2011
    SUPER Mr BRAM AND Mr GWEE !!! the engine works !!!!!!!!!
    Thank you very much :-)
  12. #9
    gwee's Avatar
    Dec 2012
    unknown
    owner of the vehicle was not honest to you, i hope you know what to do
  13. #10
    Nov 2011
    Yep, and this will be always the problem that they never tell you the real problem and who did what before you....
    Anyway, case closed, engine turns
    What algo you use to decrypt the tranponder data to eeprom data ?
  14. #11
    Moderator
    PremierD's Avatar
    Jun 2009
    The old Brain.exe mate .. what else
  15. The Following User Says Thank You to PremierD For This Useful Post:
  16. #12
    bram380's Avatar
    Aug 2009
    Quote Originally Posted by PremierD View Post
    plus a cigarette
    plus a cup of coffee
    Review "93C66 ORI ELNEC" file:
    an image is sometimes easier to understand than words
  17. #13
    Nov 2011
    seems to be a"bug", but i have no clue yet how you "decrypt" the transponder-data to the eeprom-data....
  18. #14
    gwee's Avatar
    Dec 2012
    unknown
    Quote Originally Posted by bram380 View Post
    plus a cigarette
