Results 1 to 15 of 789
Hybrid View
    Dec 2009
    E.London
    Well i've tried a few more things and i am getting no where so i've decide to buy another psu for the unit so i hope this will sort it!
    I'll post back once its arrived and fitted so you no what happened.
    May 2012
    Quote Originally Posted by miktang View Post
    Open the box and look at the Caps (Small Cylinders) they should all be flat on the top. If one is rounded its blown like a fuse. Common on these boxes. Other things can cause a dead box like the front pcb panel.
  3. The Following User Says Thank You to DW190 For This Useful Post:
    miktang (4th March, 2015)
    Dec 2009
    E.London
    Quote Originally Posted by DW190 View Post
    Thanks DW190, i looked inside the box and on the psu board there is one that looks a lot more rounded on the top compared to the others which are all flat on top. Hopefully then my new psu should fix this...fingers crossed!
    Hadron's Avatar
    Nov 2012
    E. London
    Looks like a that domed capacitor is your problem. It's a pity you didn't look at it before buying another board. You could have repaired it for less than ?1.
    If you don't know anyone that can repair it, you could get a few ? back by selling it on Ebay. Someone will buy it & repair it.
  6. The Following User Says Thank You to Hadron For This Useful Post:
    miktang (5th March, 2015)
  7. #5
    Dec 2009
    E.London
    Hi all
    the replacement psu has arrived and has been fitted to the box and everything is back up and running!!!!
    Quote Originally Posted by Hadron View Post
    I am going to look into buying the capacitor and repairing the old board and then sell it on.
    I was in too much of a rush at first to get the box up and running but now its done i will have a go at repairing the old one!
  8. The Following User Says Thank You to miktang For This Useful Post:
    Hadron (6th March, 2015)
  9. #6
    Dec 2009
    E.London
    Hi all
    Just in case anyone was interested, the capacitor that blew was 1000uf 10v and cost only 89p and took half hour desoldering old one and soldering new one on.
  10. #7
    Jul 2008
    Just fixed an s10 with the identical cap blown ! definitely a suspect batch of components at one point or under rated !!
  11. #8
    Dec 2009
    E.London
    Thanks to all, the forums pull me through again!!!!
