Results 1 to 15 of 482
Hybrid View
    Jun 2014
    Quote Originally Posted by paul_12345 View Post
    please show a bigger picture.
    also a few people have said he same issue as me, it is in the correct position - if you rotate the other way it would cut the other side too much also.
    The only difference could be the cutter - I do not see anywhere where you sell the cutter made for the condor - please post a decent picture of the cutter and where to buy the same cutter as you
    Do you mean the proper 1.5mm & 2.5 mm cutters?
    Jan 2010
    Quote Originally Posted by dustin2014 View Post
    you can not use 1.5mm as they haven't programmed it to do 2 passes to cut the correct 2.2mm width.
    2.5 is just too big even if it works I dont want some ugly key.
    I think they said it works ok with 2mm but I want a picture of the key cut with the condor and details of the cutter that cut it so I can test it.
  3. The Following 2 Users Say Thank You to paul_12345 For This Useful Post:
    dustin2014 (29th April, 2015), insomnia2009 (28th April, 2015)
    Jun 2014
    Gotcha mate.
