Results 1 to 6 of 6
Thread: VCM2 WIFI
    busaman's Avatar
    Sep 2009
    suffolk uk
    Default VCM2 WIFI
    Is it me doing something stupid i cant get the WiFi to work i have a vcm2 hq clone and it came without WiFi adapter C-LINK dwa131 my question is do i need 2 adapters one for the vcm and one for the laptop has anyone else also had this problem everything else is fine.
    7.31sec@203.3mph
    Aug 2011
    Spalding
    Quote Originally Posted by busaman View Post
    I too am trying the same and would like to know also whether you need Two.
    Does your DWA light work when in the VCM? Mine doesn't.
    It does when plugged into a laptop.
    busaman's Avatar
    Sep 2009
    suffolk uk
    i am now sure you need two but still not able to make them work (not had much time to experiment).
    7.31sec@203.3mph
  4. The Following User Says Thank You to busaman For This Useful Post:
    MJRVR (1st September, 2015)
    electronistul21's Avatar
    Nov 2011
    galati,romania
    wi -fi work with ids up to 91.01.no need adapters.module ist inside VCM.this option only in HQ clone,like original.
    Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
  6. The Following User Says Thank You to electronistul21 For This Useful Post:
    MJRVR (12th October, 2015)
  7. #5
    Jan 2014
    You should first test via USB cable;
    Then unplug the USB cable, and plug the WIFI adapter;
    Open the Internet connection interface;
    Searching for VCM2 WIFI, then click to connect.
  8. #6
    Jan 2014
    Quote Originally Posted by kikichou View Post
    Do not use the PC's internal wireless connection
    Connect to a VCM II should only be handled through the Device Selection Tab Figure.
