Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    roman_auto's Avatar
    Aug 2009
    Default Peugeot planet interface problem
    Hi all
    i new here and need your help i hope.
    I have Peugeot planet interface that stop working after dissconnect from the vechile,and now lexia3 doesnt reconize the interface.when i connect to the vechile the Green led
    flashes 3 time and go steady and no communiction.
    hope for your help its my main work.
    Thanks in advance
    Member camieltje's Avatar
    Mar 2009
    in a small country
    Hello welcome to DK
    I have the same problem like yours,I will se what the seller is going to do with this problem.
    Jul 2009
    Quote Originally Posted by camieltje View Post
    Hello welcome to DK
    Did you already tru to reprogram it proabley soft in interface bad.
    Best regards,
    roman_auto's Avatar
    Aug 2009
    Quote Originally Posted by DIAGNOSE64 View Post
    Best regards,
    hi
    what you mean reprogram interface ?
    Mar 2009
    in a small country
    Best regards,
    the seller says that i need to connect to the internet while reading out a car,just connect not do a update or something else he says.(i would like to know what is the meaning of this?)
    Is it possible to upgrade the software with this kind of chinese interface ?
    Camieltje.
    Mar 2009
    in a small country
    Mine is WORKING again,like the seller told me to put a internet connection on the PC or Laptop and start it up and read out a car and now it works again for mine interface.
    i have noticed that onley the Lexia program is with this problem the PP2000 works fine.
    I could also do a upgrade of the Lexia3 and The PP2000 true the internet and it still works fine.
    i will see in the futhere if it coninue's to work.
    Camieltje
    Newbie alilouche78's Avatar
    Jul 2009
    alger
    Camieltje
    salvation, I have the same problem as you.
    thank you for the good news.
    connecting internet once or all the time?
    thank you
    Mar 2009
    in a small country
    Quote Originally Posted by alilouche78 View Post
    thank you
    I did it one time and tested it after without and it keeps working for the moment.
    Camieltje
    Jan 2010
    europa ljubljana
    Default lexia3 problem
    HI imam naloga s svoj LEXIA 3 interface.my pc vekanje priznanih vmesnik. prosim pomoč mi.
    Jan 2010
    europa ljubljana
    sorry in english i have problem with my lexia3 please help. sorry for my english. thanks
  11. #11
    Jan 2010
    Ecuador
    take another pic, is hard to see but it seems that the driver is not working or is conflicting with another unit.
  12. #12
    Mar 2010
    Hello everybody,
    I have problem with my genuine ACTIA interface 963834-B
    /by me it is second generation of USB heads/.Working with PROXIA, LEXIA and PPS several years but after sw updates can not with PPS, still get only error message- interface is not connected or is used with another aplication. MAJAappcom can "downgrade" sw, but PPS still not accept my interface for diagnostic session.Interesting point is that PPS is able read VIN in first step when read car ID,than continue start PLANET2000 if good remember. And then get error message After Proxia conect this offer
    update interface. Working fine. Any advice please? Stupid chinesse clones working with booth sw... Thanks for help
  13. #13
    DK Veteran agabna's Avatar
    Jan 2010
    hello
    the chinese copy for peugeot have problem in the hardware the device is have two items conected by pins
    try do check the welding for the inside devices
    all of the part
  14. #14
    Mar 2010
    my one is genuine, much older than first chinesse clone
  15. #15
    I HAVE ONE EXAMPLE YOU PLEASE HELP ME
