Quote Originally Posted by martin035 View Post
Right, you could try this, it may work. This will only work if the factory default Openatv image is on the Zgemma.
A. Boot the Zgemma and carry out the post Initial boot up setup if required
Post Flash Initial Setup?( Use remote scroll left right up and down arrows as required)
System boots in German, don?t worry we?ll change that soon
1. Select your TV connectiom type ie HDMI press Ok
2. Select your TV resolution ie 1080i press Ok
3. Select your Refresh rate ie 50mhz press Ok
4. Select ?English UK? press Ok
5. Press Ok at the User Interface setup
6. Press Ok to use 'Wizard for Basic'
7. Select 'Check Internet Connection'
8. Press Ok if Internet working
9. Setup Tuner A - Config mode scroll to 'Simple' , Satellite scroll to '28'2e Astra' ,Send DISCqC to 'Yes' leave all other options default, Press Ok
10. Setup Tuner B - Config Mode 'equal to' Press Ok
11. 'No scan Later' press Ok
12. Network setup Press Ok, Press Ok again
13. Press ?Exit? again when shown the German channel Bouquets
B. Plug in your USB drive into the front USB port
C. on the Remote menu-setup-software management-flash online/local then press Yellow and yellow again
D. Find your USB drive in the list and enter each folder until you find 'rootfs' file
E. Scroll to the 'rootfs' file and press Green
The zgemma will then flash the image, when the zgemma reboots remove the front USB and insert your Storage USB into the rear and continue with instructions from setting up the USB hard drive.
So can we use this method to install from front usb all the time?
cheers
Byte
