Results 1 to 14 of 14
    Nikola123's Avatar
    Feb 2011
    Serbia
    Default EZS Viano 6395450508
    Please I need help
    I need flash and eprom from R1 and R2 mcu 1L02M, 6395450508
    Thanks in advance...
    Ezs is broken and I have ezs from vito 6395450108, and when instal and coding, car start but stay error at instrument cluster abs esp.
    When read error with star diag, I have only 2 error in esp, (no can from ezs, and wrong coding of ezs).
    May 2010
    this mcu dont have flash
    Nikola123's Avatar
    Feb 2011
    Serbia
    I think it have. Read with smok jtag. This is flash and eprom from r2mcu
    rm23's Avatar
    Dec 2009
    UK
    it has flash but you can just read it no write....
  5. The Following User Says Thank You to rm23 For This Useful Post:
    vageric (10th June, 2016)
  6. #5
    May 2010
    sorry my bad.
    wanna to sayed what rm23 sayed.
  7. #6
    Mario3's Avatar
    Dec 2014
    Did you try to change the coding with star diag ?
  8. #7
    Nikola123's Avatar
    Feb 2011
    Serbia
    Yes I try, after all possible coding options still stay same errors...
  9. #8
    Nikola123's Avatar
    Feb 2011
    Serbia
    I have option to write flash. Jtag is miracle
  10. #9
    Apr 2014
    hello,
    i have eis inside is 1L02M
    my friend repaired flash content, but write with orange 5 not possible!
    Is it right can not write to this flash ?
  11. #10
    Mar 2010
    cantabria, north spain
    Quote Originally Posted by Nikola123 View Post
    hello, I have exactly the same problem, were you able to find a solution for that?
  12. #11
    Shmortz's Avatar
    Apr 2010
    in the middle of nowhere
    find other EZS and write your eeproms in it
  13. The Following User Says Thank You to Shmortz For This Useful Post:
    tomasete (24th May, 2018)
  14. #12
    Mar 2010
    i have already done that, but r1 was lost so i changed vin and mileage of the other ezs. I get esp errors. I guess it is because the other van did not have esp. esp coding i donīt know if it is in eeprom or flash, or which chip.
    I tried to code it in developer mode but I canīt find the option to do this
  15. #13
    Feb 2010
    Birmingham
    Quote Originally Posted by tomasete View Post
    Your dump was wrong then, 1l02m have 3 different dumps with flash dictating where data is located.
    send dumps
  16. #14
    Mar 2010
    That must be the problem, because I swapped from 6395450608 1l02m to 6395450108 0l02m.
    I put eeprom from r2 and adapted eeprom dump from r1.
    DAS shows mielage and vin but I guess the dumps are not correct.
