Page 1 of 2 12 LastLast
Results 1 to 15 of 30
    marcolr's Avatar
    Apr 2010
    Default Need tunned file for Le?n 1.8 T 180cv
    Hi m8?s
    I need a good tunned file for a Seat Le?n 1.8 T with ME7.5 0261207440_1037363908. I have a tunned file made by a profesional chiptuner but I have a problem in 5? and 6? gears. When the car goes from 5000 rpm more or less, it loses power as if gasoline were not enought. The chiptuner made 2 differents files and the problem persist.
    Could someone make a good tunned file or someone have a file already modified?
    Thanks in advance.
    Best Regards
    If my post was helpful press Thanks button!!
    Jun 2013
    EU
    Log the car to see which is really the problem.
    Aug 2012
    Quote Originally Posted by marcolr View Post
    Hi m8?s
    Thanks in advance.
    Best Regards
    post the tuning file than we can check . Log boost lambda ign in the 5 gear and only 3000-6000 rpm
    post this
    Tuning Cars and Trucks, Immo off , DTC delete, DPF off
    Dec 2016
    Test this file
    marcolr's Avatar
    Apr 2010
    Quote Originally Posted by morgano View Post
    I don?t have the car here now. When the customer returns, I?ll log the car.
    marcolr's Avatar
    Apr 2010
    Quote Originally Posted by icezero2010 View Post
    post this
    Here is the two mod files. When I have the car I will log it.
    marcolr's Avatar
    Apr 2010
    Quote Originally Posted by Strykestorm View Post
    Test this file
    Thanks, I?ll try and post results.
    Regards
    Aug 2012
    Regards
    i think you must search a new tuner. files copy paste some maps forgot no ign toucht first file boost map complete wrong :-) turbo delta max 1275 mbar by stage 1
    request boost 0,8 bar
    Dec 2016
    You about my tune?
    Junior Member yvk's Avatar
    Dec 2016
    Russia
    I do not see this in the tun. Which map do you see this matter? Tell me the address of the map.
  11. #11
    Dec 2016
    Russia
    OH you about evo1? and evo2? yes, I agree with you.
  12. #12
    marcolr's Avatar
    Apr 2010
    I don?t know much about the files tuning, the truth is that this tuner has made me many files and so far they have gone quite well. But almost all are diesel cars. Maybe for gasoline he does not know too much.
    Have you looked at the Strykestorm file? Do you think that with that file the car will go well?
    Regards
  13. #13
    marcolr's Avatar
    Apr 2010
    post this
    Do you know the chanel numbers in Vag-Com to make this log in a 1.8 T??
  14. #14
    Dec 2016
    marcorl, don't be afraid! Use my tune. if first option didn't like, can give more powerful.
  15. #15
    Aug 2012
    chanel 32, 115, 2 or you use me7Logger than you can log ign and some more .
    the other file is extrem bad from skykestorm the most relevant maps untoucht
