Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: HELP MPPS v16
    Dec 2016
    Default HELP MPPS v16
    HELP MPPS v16
    I recently bought a MPPS v16 Cable online, i got it quickly but now i have a problem.
    all of my pc?s are running Windows 10. but the program cant load in other than Windows XP.
    please help me fix my problem.
    best regards ME
  2. The Following User Says Thank You to MCfite For This Useful Post:
    daily drive (20th April, 2020)
  3. #2
    Jan 2014
    From what I know operating systems it Must be Windows xp I heard anything higher was always a problem
    doctore's Avatar
    Nov 2015
    Colorado Denver
    tray in propertis from mmps icon compatibility mode put in xp sp3
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
    Sep 2016
    Let me guess you have the shitty loader type mpps ? If yes then try this http://www.digital-kaos.co.uk/forums...9&d=1448718347 Works like charm for me.
  6. The Following 7 Users Say Thank You to EddieMoney For This Useful Post:
    barnatkcs (31st August, 2020), Boyes (8th November, 2021), daily drive (20th April, 2020), Ecumotor (25th December, 2019), ivanrojo (14th November, 2017), qeen (1st May, 2024), semediag (22nd December, 2016)
  7. #5
    Dec 2016
    Essex
    Hi Mcfite.
    Did you resolve this - I'm having the same problem trying to run MPPS V16 on windows 7. I have the loader type and its full of problems. Sometimes it will load and sometimes not and all crashes when I try to connect to the car.
  8. #6
    Feb 2017
    are you running the program in compatibility mode?
  9. #7
    norman1967's Avatar
    Dec 2015
    Amsterdam
    ive had all these headaches with shitty 1.6 its in the bin now. v1.8 and v1.3 all the way. zero issues
    Genuine tools including Abritus, Autotuner Master, Bosch Ford vcm2, smok UCDS FULL JTAG FULL pcm flash, IO terminal, UPA, Autel maxicom pro, MTX dpf, dtc, immo edc17 UCDS, and a little well maintained hairy box from china I play inside!
    4.94 x100 fgtech kess ktm ktag mpps skp. And still collecting
  10. #8
    Feb 2017
    Eu
    be very carefull with MPPS. i bricked an edc16 with mpps.
    make sure you have a full bdm backup!
  11. #9
    Feb 2019
    Thank you EddieMoney!!!!
    I used your suggestion and it worked.
    I used MPPS V16 on Windows 10 64bit, your version with no loader. I had a few snags with the crappy loader version provided by the seller.
    Make sure you run it on compatibility for Windows XP SP3. Make sure dongle is connected when you are running program or it will not run.
  12. #10
    Jul 2019
    I have the same problem. But on win xp.. nothing work. I install fresh xp on laptop.. its need any software for work ? Net framework or something like that? Thank you guys.
  13. #11
    Jul 2019
    Quote Originally Posted by mexscirocco View Post
    Did this fix your problems
  14. #12
    Jan 2019
    Somewhere between Continents
    Hello guys, hope someone can help me out...
    I just got the MPPS V16 (clone) and i´m trying to read an ECU ME1.5.5 but i´m getting 2 errors:
    One is: "Maximum Number of attemps reached" (cant remember the exact error words now, but is something like this)
    The other is: "Invalid Key"
    When i do the ECU INFO (F1), it gives me the VIN number and version, but when i press "Read" (F2), i get these errors...
    Sometimes its the 1st, other times its the 2nd one.
    And it always gives me the "Error Windows" to send Log.
    Can anyone tell me that this might be?
    I already tried several times to read this ECU with Kess V2, but i cant read it...
    This is from a Mexican Chevrolet Model (similar to EU Opel Corsa C 1.6 8V)
    If anyone can give me some tips i would really appreciate...
    Just Consider helping Freely like I want to do...
    Thanks and Rep are Always Welcome...
  15. #13
    Mar 2023
    i also solved the problem of mpps on windows 10! i reccomend this version
    thank you very much!
  16. #14
    Jan 2024
    Quote Originally Posted by EddieMoney View Post
    i cant get this to download anyone have a link
  17. #15
    Senior Member smotorsport's Avatar
    Feb 2018
    Has anyone found a solution to make it work on WIN 11 x64. My version works without any problems on win10 x64 but on win11 always error access violation at address 00000001
    Don't forget to press Thanks and Rep button if helped!
