Results 1 to 4 of 4
    Andrei2015's Avatar
    Oct 2015
    Default 2005 smart forfour BSI/SAM milleage
    I need help reseting milleage in BSI/SAM from a 2005 smart forfour :
    Siemens 5wk4 5104c with processor 9s12dg128. I attach file read with UPA, current milleage is 278.xxx km
    Thank you very much smart 4four EEP.bin 8.rar
    Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
    VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
    POPS & BANGS (Schubabschaltung, Crackles)
    Fec001's Avatar
    Apr 2010
    If your read is ok and have 253.xxx km, then here is dump with 0km. But it's strange there is no VIN in your dump
  3. The Following User Says Thank You to Fec001 For This Useful Post:
    Andrei2015 (18th July, 2017)
    Dr. Zoidberg's Avatar
    Oct 2015
    Talca-Chile.
    Quote Originally Posted by Fec001 View Post
    I think the reading is bad, and if you write this file, the car will be dead
  5. The Following User Says Thank You to Dr. Zoidberg For This Useful Post:
  6. #4
    Andrei2015's Avatar
    Oct 2015
    I figured it out something was wrong with read, I have read 2 times with Smok and 6 times with UPA. Smok read was same but UPA got it different all times. Finally did just dash and SAM wasn't changing milleage in DASH
