24c04 no_immo.zip
With this file car works 100% - checked in my workshop
But you have to:
1) cut immo line pin 37 (blue/gray) of engine ecu
2) give additional ground on relay called "SM" in engine fusebox (starter motor relay)
3) remove alarm module (behind radio) and desolder buzer from inside
4) cut 4th pin from the smallest plug (3rd one) blue/pink - this is red immo diode on dash
5) if engine check light is on cut also pin 42 of engine ecu (YELLOW/RED OR GREEN/RED)
Works fine
