Page 39 of 50 FirstFirst ... 29343536373839404142434449 ... LastLast
Results 571 to 585 of 747
  1. #571
    Apr 2012
    London
    Quote Originally Posted by tiugrikas View Post
    Hi did you read write by obd ? Cause mine only read by obd but no write and i dont know why
    Išsiųsta naudojantis HUAWEI TIT-L01 Tapatalk 4 Lt
    HI!
    YES READ/WRITE by OBD
    some other PSG16 I had to read and write directly via connector on PSG16 because by OBD no connection established.
  2. #572
    DR Race's Avatar
    Dec 2017
    Dracula's country
    Default mpps read check
    hy guys .can somebody check a file for me .i am new on mmps,i have no win ols but i think this car is already tuned ,thenks in advance!!
  3. #573
    Mar 2014
    Lithuania
    Quote Originally Posted by DR Race View Post
    No, car don't tiuned, this is most similar ori file
  4. The Following User Says Thank You to mysterious For This Useful Post:
    DR Race (9th February, 2018)
  5. #574
    DR Race's Avatar
    Dec 2017
    Dracula's country
    Quote Originally Posted by mysterious View Post
    File look ok ??? First time using this mpps !
    Trimis de pe al meu SM-G930F folosind Tapatalk
  6. #575
    Mar 2014
    Lithuania
    Try read with another tool and I will compare
  7. The Following User Says Thank You to mysterious For This Useful Post:
    DR Race (10th February, 2018)
  8. #576
    May 2014
    LIthuania
    Quote Originally Posted by zyjekrc51 View Post
    HI!
    yes I tryed write via connector with two vectra c but still no result and also cant read write audi vw edc17 anyone has experience with it too ?
  9. #577
    sdtsedat's Avatar
    Jan 2015
    Belgium
    Quote Originally Posted by maybach_ View Post
    Hi mates
    I have a V18 Clone and want to read my Berlingo ECU with EDC17C10 but can't see whare are the meny for EDC17 ecu
    can someone help add video or foto how to do
    Thanks in advance
    Edc17c10 always bootmode.
    Verstuurd vanaf mijn SM-A520F met Tapatalk
    Sedat Garip
    Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
    Diesel + petrol All cars
    Manual Adblue dpf egr Opf tested working solutions
    Belgium
    With Kind Regards,
    Don't forget hit thank button if i helped.
  10. The Following 2 Users Say Thank You to sdtsedat For This Useful Post:
    Col19 (24th December, 2019), maybach_ (12th February, 2018)
  11. #578
    Jul 2010
    italy
    Hello to all,
    I have a problem on my V18 china.
    it worked great until now.
    since yesterday, the sw starts, everything works,
    but can not find more ecu (kline or can)
    does anyone have a fix for the components?
    use thanks please
  12. #579
    Dec 2010
    Quote Originally Posted by bocaje View Post
    hello.
    EDC16C2 W203 mercedes mpps v18 EU CLONE not work ...
    regards
    W639 Vito EDC16C2 MPPS V18 doesn't work either, invalid seed key. Had same on a Golf MK5 GT BKD 2.0 TDI too today which is odd (2005).
    MPPS Standalone Master, Magpro Base + X17, Dimsport New Genius, Piasini, Galletto V53, Kess V2, K-Tag, Trasdata remapping tools | OP-COM, VCDS, Fiat MultiECUScan, Ford F Super, Renault CAN Clip V124, INPA/NCS Expert + others.
  13. The Following User Says Thank You to poxxxy For This Useful Post:
  14. #580
    Member fabiof1's Avatar
    Jan 2012
    Hi I'm looking for a notice edc17cp14 with Mpps v18 EU Experience? Possibility obd? Boot?
    Thank you
  15. #581
    Jan 2014
    Ro
    view post nr 459..
  16. #582
    Jan 2012
    Ok thanks.
    but how to make for tprot level ? If active or not ?
    I know that with an original kess in obd wrote it and it detects the level of the tprot.
    But mpps?
  17. #583
    teamtuner's Avatar
    May 2015
    TRANSILVANIA
    Quote Originally Posted by fabiof1 View Post
    Ok thanks.
    But mpps?
    use only boot mode
    inside forum:ask me about...i will tell you all that i know
    make me working for you...i will give you my paypal account
    outside forum:
    chiptuning,egr,dpf,add blue,dtc,Eu clones
  18. #584
    Jan 2012
    Yes I think...
    but just for read ecu no problem in obd with Mpps...
  19. #585
    Jan 2012
    Latest question....
    Mpps v18 Europe ( Carprog eu )
    what is better clone :
    kess v2 5.017 / or / Mpps v18 ......
    I would like Your opinion .
