Page 1 of 2 12 LastLast
Results 1 to 15 of 17
    Apr 2016
    Evere 1140
    Default renault trafic immo problem
    i have problem with immo red blink flashing
    renault trafic 2007
    ecu 0281012658 how can i fix immo thanks for helping
    little bb
    Mar 2018
    UK
    Quote Originally Posted by repair4 View Post
    renault trafic 2007
    Check the key transponder
    Check the coil on ignition lock
    Program new key
    Apr 2016
    Evere 1140
    Can i make immo off
    little bb
    Mar 2018
    UK
    Can i make immo off
    Do you have key from this van or all keys lost?
    Apr 2016
    Evere 1140
    All keys lost
    little bb
    lion0304's Avatar
    Oct 2014
    All keys lost
    Make new key more faster than immo off.
    Dec 2010
    Nottingham
    pick decode . cut key and program it in , 10 minute job
    Mar 2018
    UK
    He have the key - if havent how can see that immo blink
    maybe is possible to repair it - change the key coil
    Meat-Head's Avatar
    Quote Originally Posted by Manta1600 View Post
    It’s fkcued, you need a new one.
    Any advance on this, feel free
    jodge's Avatar
    Mar 2017
    immo off is pain in the ass.
    you need emulator and cut the can line. If you need the rpm + temp then you will need to install a switch between the ecu and the dash. Funny job
    Sir, are you classified as human? Negative, I am a meat popsicle
  11. The Following User Says Thank You to jodge For This Useful Post:
    Meat-Head (29th October, 2019)
  12. #11
    avital's Avatar
    May 2010
    It not true (about cut lines) not for all types emulators cut is needed it is depend of software implemented inside emulator.
    Production and development professional IMMOBILIZER/TCU/ESL/ELV/SRS emulators for all brand cars
    PORSCHE / FERRARI / MASERATI / LAMBORGHINI - immobilizer solutions
  13. #12
    Meat-Head's Avatar
    Well send a link in your next post
  14. #13
    avital's Avatar
    May 2010
    Link for Renault the emulator immo with implemented special software : http://www.ecudiag.es/home/2796-emul...-500-kbps.html
  15. The Following 2 Users Say Thank You to avital For This Useful Post:
    jodge (31st October, 2019), Meat-Head (1st November, 2019)
  16. #14
    jodge's Avatar
    Mar 2017
    Also is implemented „stealth” software technology - in 99% cases
    don't need cut canbus network and do not need to use a relay.
    yupp something similar with the italian guys stuff... almost 99% i made a few pcs in the last month and 2 of them need to be cutted. maybe it's bad luck or depend on the UCH sw dunno
    BTW thx for the useful link
  17. #15
    avital's Avatar
    May 2010
    Cut wire need ONLY when CANBUS line beyond out the motor controller , further (deeper) in the electrical system is broken like grounded, damage or up to 12v .
    If want real deep investigation give logs from CANBUS I teel You what is problem , because I wrote the software for this emulator...
  18. The Following 2 Users Say Thank You to avital For This Useful Post:
    jodge (1st November, 2019), Meat-Head (1st November, 2019)
