excuseme for top speak is problem traslate.i change bsi because i program key with lexia when no star engine.i put bsi scrapping ? whit number vin of the car crasch
thankyou
thankyou
hello again i would know if i delete the personal key to a scrapping bsi and put it in virgin mode
AFAIK
The BSI can only be paired ONCE to an ECU (according to PSA) re-synching is sometimes required.
The BSI can be replaced with a virgin one and paired to the original ECU (sometimes!! tool has an option for factory help!)
Keys can all be cleared, relearned, replaced or added any way you want.
3 wrong security login attempts will lockup the BSI... permanently (according to PSA)
There are virgin dumps for the BSI about
sorry to butt in ...did you use a new key or original for the car???
good question... is it a valid key?
If the transponder fails or is missing from the key the learn new key process tries five times then reports a failed operation.
thats right... the key tranponder and remote fob can only be programmed once then you must replace ,you can just buy a new transponder type 46 crypto i think and put in the key.new fob can be bought from hickleys.
