Page 726 of 854 FirstFirst ... 226626676716721722723724725726727728729730731736776826 ... LastLast
Results 10,876 to 10,890 of 12803
  1. #10876
    Oct 2019
    somebody knows the security code of central eletric? i need to code led bulp warning but i cannot go in security acces:
    i need to do exactly like this video:
    but this guy his car is UDS and he enter 31347 and the key is valid
    mine car is CAN and when i insert 31347 key is invalid
    image of youtube
    image of mine car
    also i don't get yellow popup with the right key but this guy on youtube get yellow popup with the key.
  2. The Following User Says Thank You to armo For This Useful Post:
    seal777 (21st May, 2021)
  3. #10877
    May 2010
    EU
    Quote Originally Posted by armo View Post
    There is no security access login in that clb. Not even one.
  4. #10878
    Dec 2020
    Quote Originally Posted by drdahmani2 View Post
    I WOULD LIKE TO TEST FOR DUMPING FIRMWARE
    ANYONE HAS ANY IDEA ABOUT THE PINOUT TO CONNECT THE SWD STM32 DEBUGGER, THANKS FOR SHARING
    From J2 and right (the one with the small square) you have [VDD(+3.3v), GND, PA15, SWDIO, SWCLK, PB3] (The side of the PCB with the STM chip)
    Both the bootloader and the firmware will check the RDP level and set RDP2 if not previously set.
    This will completely disable the debug interface so you wont get any response if you connect a debugger.
    Here are some info from ST about RDP2:
    "When RDP Level 2 is activated, all protections provided in Level 1 are active and the MCU is fully protected.
    The RDP option byte and all other option bytes are frozen and can no longer be modified. The JTAG, SWV
    (single-wire viewer), ETM, and boundary scan are all disabled. When booting from Flash, the memory content
    is accessible to user code. However, booting from SRAM or from system memory bootloader is no longer possible.
    This protection is irreversible (JTAG fuse), so it is impossible to go back to protection Level1 or 0."
    Despite this I found a way to revert it so I would not say it is impossible. When that said it took me nearly a year of research to figure it out.
    Good luck trying
  5. The Following 6 Users Say Thank You to badrax For This Useful Post:
    Col19 (23rd May, 2021), drdahmani2 (22nd May, 2021), jakuza (23rd June, 2021), jan4 (21st May, 2021), kaalis (21st May, 2021), Martin700 (2nd November, 2024)
  6. #10879
    Nov 2020
    somebody knows if you can acces security acces 16 from 09 central elektric, the code is 31347 but i cannot go in, i bought mine hex v2 from flyfvdi.
    Attachment 810013
    contact me, the support engineers can help you
  7. #10880
    Nov 2020
    Quote Originally Posted by miouser View Post
    found on the net
    415 burn out too!
    carhelp.info/forums/showthread.php?t=153136
    no new MIC2920A-5.0WS to buy and use,
    no new DADU tpo buy and use,
    the secondhand MIC2920A-5.0WS and DADU, most are working well , but some are not working well.
    so some burned out
  8. The Following User Says Thank You to flyfvdi For This Useful Post:
  9. #10881
    Mar 2009
    anyone please have arm 415 fix or is there no fix for these cable shows illegal interface in vip loader
  10. #10882
    Col19's Avatar
    Jan 2019
    France
    Hi friends
    Who can share the part number of the PZ1 component to me please ?
    Thank you in advance.
  11. #10883
    Top Poster jan4's Avatar
    May 2018
    somewhere in Belgium
    @ col19
    does not work , no use of soldering it in !!
  12. The Following User Says Thank You to jan4 For This Useful Post:
    Col19 (4th June, 2021)
  13. #10884
    May 2021
    Default goismi lakhdar
    يعمل 100/100 على الاصلي هاذا اخر تحديث 3/2021
  14. The Following User Says Thank You to lakhdar lakhdar For This Useful Post:
  15. #10885
    Feb 2018
    which interface can be used with this program, which cable, hello
  16. #10886
    Dec 2014
    PL
    Quote Originally Posted by zoki21 View Post
    You can use VAG DASHCOM / CAN 5.29 interface.
  17. The Following User Says Thank You to Mario6 For This Useful Post:
  18. #10887
    Apr 2020
    Hi guys, I'm using a V2 interface with STM405 and if I use latest VII plus loader 08.021.05 with 21.3 version I get license error when trying to scan a car and "license revoked" at About menu. If I use 20.12 version it seems al is ok. As I know latest loader is suppose to work with latest version of VCDS. My interface SN ends with -5a22, am I doing something wrong ?
  19. #10888
    Jul 2019
    where I can finde on Aliexpress the vcds hex-v2 with the DADU DFN8 or SIT1050 DFN8 ship? Thanks a lot
  20. #10889
    Mar 2019
    I bought an interface and indeed the chip seems to be second hand and just added later (considering the bad quality of soldering)
    Picture here: https://postimg.cc/cg43zgbZ
  21. #10890
    Dec 2020
    Anyone using the 415 cable experience burned chips?
    Or perhaps more specific anyone with an upgraded 415 (to support 20.12) expenses this?
  22. The Following User Says Thank You to badrax For This Useful Post:
