Results 1 to 10 of 10
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    Default FRM3 9S12XEQ384 3M25J X-prog 5.5.5
    Howzit
    Need some advice tried to read D Flash data with XProg Box 5.5.5 clone no dongle software - having this error Unknown MC9S12 device .Part ID:0x2004C482
    Tried to read a few times same error just the Part ID that change to 0x0024C48A
    At some stage I got error Partition corrupted Partition dump: 00 00 00 10 Select partition size manually
    Advice appreciated
    'If I helped, please click Thanks +Reputation.. !'
    mexanico1971's Avatar
    portugal
    If all the connections are good in the FRM pcb , can be Dflash problem
    Can you read P-Flash or eee ?
    My work is my life ART TECH GARAGE
  3. The Following User Says Thank You to mexanico1971 For This Useful Post:
    rtbdiagnostic (5th August, 2021)
    May 2015
    My Tool Room
    I tried to read d - flash with upa usb reads quick but dump differs everytime - I did read P-flash with i-prog
    Never tried to read p-flash or eee with x-prog
    Would you think better to downgrade to perhaps 5.5.1 would it be more stable perhaps
    portugal
    Check connections again
    Graab other dumps width same numbers and coded it
  6. The Following User Says Thank You to mexanico1971 For This Useful Post:
  7. #5
    kiszka's Avatar
    Aug 2009
    Quote Originally Posted by rtbdiagnostic View Post
    firmware version 5.5.5 is very unstable even with eeprom spi reading
    so anything is possible
    Reality of life :
    1:Never argue with an idiot, he will drag you down to his level and beat you with experience
    2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
    3:Jealousy is a sign of inferiority
    4:Everyone lies
    How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
    If you like to read garbage, don't slow down, just speed up
  8. The Following User Says Thank You to kiszka For This Useful Post:
    rtbdiagnostic (6th August, 2021)
  9. #6
    May 2015
    My Tool Room
    Found this procedure to downgrade would it be the correct way to follow to get back to 5.5.1 firmware
    https://www.e90post.com/forums/showthread.php?t=1838104
  10. The Following User Says Thank You to rtbdiagnostic For This Useful Post:
    digimile (21st October, 2021)
  11. #7
    May 2015
    My Tool Room
    Quote Originally Posted by kiszka View Post
    Would you recommend X-prog 5.84 to read write FRM
  12. #8
    May 2015
    My Tool Room
    Or would it be advisable to install on Windows XP 32 bit OS instead of Windows 7 64 bit
  13. #9
    May 2015
    My Tool Room
    Quote Originally Posted by mexanico1971 View Post
    Is it necessary to short X-tal on the FRM PCB
  14. #10
    Oct 2015
    XPROG 5.55 in config have not ic with 0004c482
