Page 735 of 854 FirstFirst ... 235635685725730731732733734735736737738739740745785835 ... LastLast
Results 11,011 to 11,025 of 12803
  1. #11011
    Top Poster jan4's Avatar
    May 2018
    somewhere in Belgium
    mostly the eu prices are at the same level as china+tax , the only benefit is faster delivery .
    use the search option on ali to find out , but right now most eu are 162 cables
  2. The Following 2 Users Say Thank You to jan4 For This Useful Post:
    Defon (18th August, 2021), fuzz1 (15th August, 2021)
  3. #11012
    Nov 2020
    FLY VCDS Hex-V2 with main chip STM405 or STM407 or STM429 and VII PLus Loader.
  4. The Following 2 Users Say Thank You to flyfvdi For This Useful Post:
    Col19 (20th August, 2021), kaalis (16th August, 2021)
  5. #11013
    Aug 2018
    France
    @flyfvdi :
    what is différence bitween this 3 models ?
  6. #11014
    Nov 2020
    Quote Originally Posted by ZIPPO4594 View Post
    @flyfvdi :
    Same functions with (STM405 or STM407 or STM429)
  7. #11015
    Feb 2018
    Quote Originally Posted by flyfvdi View Post
    I follow your posts and saw 3 versions
    V1 without large capacitor
    V2 with 1 large capacitor
    V3 with 2 large capacitor
    Are there any other changes?
  8. #11016
    Apr 2021
    Hi guys,
    I just got the new Hex V2 STM32F405, which is the latest VIILoader?
    Im used to using the Kolimer Loader, is it the same procedure for make the VIILoader works?
    EDIT
    Solved.
    Found the 08.021.06 , it works.
  9. #11017
    fuzz1's Avatar
    Jul 2019
    Quote Originally Posted by Za589 View Post
    Hi guys,
    EDIT
    Solved.
    what have you been able to do with it so far?
  10. #11018
    Mar 2019
    does anyone know what to get damaged in the cable when VIIPlusLoader returns 0x0000630b error?
  11. #11019
    electronistul21's Avatar
    Nov 2011
    galati,romania
    I have one interface HEX V2 21.3.0 ,with Atmega162 chip.After some time is deactived.I flashing chip Atmega with MiniPro and using project from loader.After this i have errpr interface not found and green LED is off.I see interface in device manager corect ,but when open software interface not found.What is diferent for this version?I make this job many time before and all is ok but this time failed
    Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
  12. #11020
    Aug 2018
    Romania
    If when testing the interface the result is "interface not found", it seems a problem with FTDI, it would be worth rewriting with MProg.
    Do not forget to press Thanks and Reputation buttons!
  13. The Following User Says Thank You to sebage For This Useful Post:
    electronistul21 (22nd August, 2021)
  14. #11021
    Nov 2011
    galati,romania
    I rewrite FTDI ,i see corect in device manager how RossTech direct interface,driver is ok.But when make C-test i have mesage ,,No response",whhen try HWtype same mesage.Green LED is off ,and interface ahve suplly voltage from OBD2.Is very strange because MiniPro report me succseful programed,i verify and all is ok,inclusiv fusebits and config.
  15. #11022
    Nov 2020
    Quote Originally Posted by Gracek View Post
    do not care the changes, same functions, better and better
  16. #11023
    Nov 2020
    Quote Originally Posted by fuzz1 View Post
    Kolimer Loader is not VII PLus Loader, two different company tool
    VCDS Hex-V2 with main chip STM32F405VGT6 and VII PLus Loader. full version, update freely. most stable.
    VCDS hex-v2 is also available in the following languages:
    Chinese, Croatian, Czech, Danish, English, French, German, Hungarian, Italian, Polish, Portuguese, Romanian, Russian, Spanish, Swedish
    VII PLus Loader support Polish,German,French,Romanian,Czech,English,Chines e.
  17. The Following User Says Thank You to flyfvdi For This Useful Post:
    fuzz1 (23rd August, 2021)
  18. #11024
    Nov 2020
    Quote Originally Posted by MaTyyyspl View Post
    pleasse contact VCDS Hex-V2 with main chip STM32F405VGT6 and VII PLus Loader fly company technical support engineers.
  19. #11025
    Mar 2019
    Terry tell me only "send cable to us" and run loader as administrator...
