Results 1 to 14 of 14
    Member obdshop's Avatar
    Jun 2016
    EUROPE
    Default BMW E70 X5 CAS 3 epp Demage AKL ( F I X ) epprom
    Maybe anyone can help me and Fix Epprom from CAS3 i am nearly sure the epp is Problem i buy other CAS whit same number and try whit ORI epp
    but same Problem nothing happens dont see Key or anything whit other CAS "works" see Key and message wrong key in IC but whit my ORI CAS all is dead !
    CAS 3
    61.35-9147217-01
    (2082402057)
    5WK4 9514VBR
    OL15Y MASK
    Attacched i have ORI CAS Data (Flash and EPP) same from new (DONOR) CAS and ECU Full Read
    Maybe anyone can fix Epprom DATA??
    THANKS to ALL
    "CAS read whit VVDI Prog ECU whit KTAG"
    eliet2000's Avatar
    Sep 2011
    Pixa-Roglet / Valencia / Spain
    Write this file in Cas Eeprom, and try repair kit VVDI2
    Pepelno Vds Pro
    Mangarrufa Power Solutions
    thank you is free
    Jun 2016
    EUROPE
    thx but i dont have VVDI2 any other idea??
    brend's Avatar
    Oct 2015
    Same where
    Quote Originally Posted by obdshop View Post
    That's eep dump and for write vvd2 not necessary , all genuine bench mcu progrmmer can do this without problem .
    NB!!! Don't ask in PM old file password , Im not remember.
    Jun 2016
    EUROPE
    Sure but her write " Write this file in Cas Eeprom, and try repair kit VVDI2"
    Maybe i am wrong but whitout VVDI 2 cant do Repair Kit ??? Maybe you know better ??
    i write this epp to CAS is same like before DEAD hope still anyone know how to fix EPP and can help
    anyway Thanks for your replay is really helpful
    Jun 2016
    EUROPE
    Friend Thanks for the epp file i test it but not works
    i will ask one friend whit VVDI2 to try this repair KIT
    Jun 2016
    EUROPE
    Quote Originally Posted by eliet2000 View Post
    eliet2000's Avatar
    Sep 2011
    Try write in 0x0F90 DA AA 55 in EPP with external programer, and put the unit in the car.
    Conect VVDi2 to OBD2 vehicle and try update flash with repair kit CAS3+
    Pepelno Vds Pro
    thank you is free
    Jun 2016
    EUROPE
    THANKS BUT LIKE I SAY I DONT HAVE VVDI2 AND NOW I CHECK IN VVDI2 SAME ONNLY HAAVE REPAIR FUNCTION FOR CAS 1 & 2 i dont see for CAS 3 repair solution in VVDI2
    Feb 2019
    Your eeprom is corrupt
  11. #11
    Jun 2016
    EUROPE
    Quote Originally Posted by looneyman View Post
    Thanks thats why i ask for fix it
  12. #12
    May 2020
    tot557545@gmail.com
    obdshop look you ori cas3+ eeprom and flash all ok,whats you problem friend?
    ori cas3+ all info
    VIN: WBAFE810X0L095770
    KM: 230675 km
    Key cutting code:HA00019778
    CAS remote control frequency:868Mhz
    CAS ID: 9389116
    The loaded CAS file no need fix!
    ori ecu isn = ECU synchronize code: 2D54
    FRIEND PLEASE PRESS THNX BUTTON AND REPUTATION
    TEST AND REPORT WRITE REP ORI EEPROM TO ORI CAS
    FRIEND cas working with ECU and Gearbox synchronize code, not use only ecu isn
  13. The Following 5 Users Say Thank You to ecuprogramer For This Useful Post:
    alex_r_2001 (24th August, 2022), brend (24th August, 2022), eliet2000 (24th August, 2022), obdshop (24th August, 2022)
  14. #13
    Jun 2016
    EUROPE
    Quote Originally Posted by ecuprogramer View Post
    ori cas3+ all info
    KM: 230675 km
    CAS ID: 9389116
    OK THANKS maybe my ORI cas have any HW distrubs i just know whit my ORI cas car is like dead i connect other cas and car like wake up and see key but shows on dash wrong key think is normal i not cas from other car .
    so i see problem is in cas thats why i think cas is lost data i buy same cas and copy my epp from oti to other cas same still car is like dead
  15. #14
    May 2020
    tot557545@gmail.com
    obdshop after learn all key
