Page 796 of 854 FirstFirst ... 296696746786791792793794795796797798799800801806846 ... LastLast
Results 11,926 to 11,940 of 12803
  1. #11926
    Nov 2018
    Thank you. Did you try it with VCDS 23.30? Are security codes now working? Thanks.
  2. #11927
    Feb 2019
    Quote Originally Posted by mickyjenny View Post
    In short, no it's still not working with security codes...
  3. The Following User Says Thank You to carpcat For This Useful Post:
    mickyjenny (9th March, 2023)
  4. #11928
    Mar 2023
    Quote Originally Posted by carpcat View Post
    It means still, last working version is VCDS 21.9?
  5. #11929
    Feb 2019
    Quote Originally Posted by Gentoo View Post
    Yes Correct
  6. #11930
    Jan 2023
    If security access was not working for you, could you try once again with the german VCDS version? For me it works fine, while the english version doesn't!
  7. #11931
    I have buy a vcds clone , and i try to install 20.4.2 or 22.1 release and try whit loader 9.1 or 9.2 but still not working when i it the loader it shows the blue square vcds loader god bless kolimer x86 9.1 or 9.2 but then the square disaper and the prog does not load , im working on windows 7 professional 32bit
    any one have this problem ???
  8. #11932
    Jan 2023
    Tested the german version? (maan... why does nobody test that? o.O)
  9. #11933
    Dobermann's Avatar
    Germany
    Quote Originally Posted by klsdjfklsdjflks View Post
    what version do you exactly test ?
    Rosstech DRV 22.10
    MM Flex Full , KESS3, KESS V2 and KTAG Original , ECM Titanium Genuine, CarProg V14, MPPS V22
  10. #11934
    Nov 2018
    I downloaded 22.10 german and 22.3.1 italian (in this case they told me to use V2PlusLoader-08.022.07-PTT&ITT&EST as loader), I will try in the next days and I will let you know if security access works.
  11. The Following User Says Thank You to mickyjenny For This Useful Post:
    Dobermann (10th March, 2023)
  12. #11935
    Col19's Avatar
    Jan 2019
    France
    The fly spokesperson fled apa2:after the last decryption message from BADRAX
  13. #11936
    Col19's Avatar
    Jan 2019
    France
    BADRAX alias Futur KOLIMER.
  14. #11937
    Nov 2020
    vcds hex-v2 languages to VIIPLusLoader version
  15. #11938
    Feb 2019
    The answer is simple: English also works without a loader, the other language versions ONLY through the loader. Any software run through the loader NO LONGER HAS that security code access bug. If English is run through VIIPLUSLOADER, Access security code will work without problems. Because of this, it appears that the German software does not have that bug, because it is run through VIIPLUSLOADER.
  16. #11939
    Mar 2023
    Hi annyone have a link to can commander v3,6 ???
  17. #11940
    Nov 2018
    Quote Originally Posted by Gimse View Post
    With the english version I have the security code bug also through the loader. At least in the ABS module.
  18. The Following User Says Thank You to mickyjenny For This Useful Post:
    jan4 (10th March, 2023)
