Page 1 of 3 123 LastLast
Results 1 to 15 of 37
    Jun 2023
    Brazil
    Default Mappack for SIRIUS 32 renault clio 2 1.6 16v
    Hello friends,
    Here is a simple mappack project, based on an ECM-TITANIUM driver from a sirius 32 from a renault clio 1.6 16v (K4m)....
    It may help someone,,, if you find more things, be sure to share this map with the community...
    and please,, no passwords,,,, it is a very old ECU and there is no reason to keep knowledge of something that is already known by many people and can help many enthusiasts and beginners like me
    hugs to all...
  2. The Following 8 Users Say Thank You to viniciooswilson For This Useful Post:
    Antelo1111 (25th July, 2023), boost turbo (25th July, 2023), Leopomim (26th July, 2023), mimodiag (5th February, 2025), muonlineonline (11th October, 2024), raphouael (5th May, 2024), youfarid (15th June, 2024)
  3. #2
    Nov 2022
    Thanks, I've been looking for this, what's wrong with the first rev limiter?
    Also, do you know how I can raise the idle speed?
  4. The Following User Says Thank You to Antelo1111 For This Useful Post:
    viniciooswilson (26th July, 2023)
  5. #3
    Mar 2023
    Brazil
    Thanks Vini, I've been looking for this for a long time.
  6. The Following User Says Thank You to Leopomim For This Useful Post:
  7. #4
    Jun 2023
    Brazil
    Quote Originally Posted by Antelo1111 View Post
    Unfortunately, I can't tell you where the idle rpm is in the file... for that, you would need a damos, or put more ignition advance at low rpm, but I don't advise it, since it could result in pre-detonation and other things... ..
    about the RPM limiter with the information not to use it, I did this because checking maps of two renaults clio, in both this block was always with ff value, which results in an irregular number (very high, 255 in 8 bits and taking into considering that we would have an offset of 260 in this field, we could reach 65535, which is an absurd number and probably incorrect, so I imagine that this block present in the ECM-titanium driver may refer to another Sirius ECU module that has more rpm limiters ), so I believe this information is incorrect.
  8. The Following 2 Users Say Thank You to viniciooswilson For This Useful Post:
    Antelo1111 (28th July, 2023)
  9. #5
    Feb 2010
    WALES
    Quote Originally Posted by viniciooswilson View Post
    Hello friends,
    hugs to all...
    Can you save it as .CSV ?
    I have a full Damos for this, including factors
    tia
    wbr
  10. #6
    Jun 2023
    Brazil
    Wink
    Quote Originally Posted by shooting View Post
    tia
    wbr
    Of course friend, follow the mappack in CSV format,,, and of course no password
  11. The Following User Says Thank You to viniciooswilson For This Useful Post:
    shooting (27th July, 2023)
  12. #7
    Feb 2010
    WALES
    I mean can you export from winols to .CSV , it makes a text mappack I can use
    wbr
  13. The Following User Says Thank You to shooting For This Useful Post:
    viniciooswilson (28th July, 2023)
  14. #8
    Nov 2022
    Good job anyway, since you guys know, can anybody help me with my idle problem?
    I have a S110138000 sirius32n (1.4 16v Clio ph1), it runs the engine from scenic 1.6 16v k4m, a local guy did immo off on my ECU but since then the idle has been low and rich.
    I couldn't dump it since the ktag gave me a checksum error but I've tried flashing a file from the net with the same code and the car runs the same.
    Is there something to be done, also can anyone guide me to flashing a 1.6 16v software on my ecu?
    i think that would help with my idle problem
  15. The Following User Says Thank You to Antelo1111 For This Useful Post:
  16. #9
    alonedark's Avatar
    Feb 2017
    Of this everything is already invented
  17. The Following User Says Thank You to alonedark For This Useful Post:
  18. #10
    Jun 2023
    Brazil
    wbr
    Here is the map list in csv exported on winols 4.7 and a image with the map addres
  19. #11
    Feb 2010
    WALES
    Your image has wrong addresses for injection, should be $8391 and $85AD for K4M engine
    also there should be at least 13 maps for OBD2 read 32k/256k
    wbr
  20. The Following User Says Thank You to shooting For This Useful Post:
    viniciooswilson (17th August, 2023)
  21. #12
    Aug 2023
    France
    wbr
    Hi everyone,
    I am on the subject of sirius 32 for k4m renault clio 2 also.
    I also have the map ecm titanium and I can assure you that the map rpm limiter are ok and working. The addresses of vini are almost correct but depend on the calculator. There are 3 values: rpm limit 1; rpm limit 2; rpm limit 3. By changing the 3 it works on the voiruee.
    But I am looking for the other real map of advances to ignition (full load) and injection.
    Shooting do you have a damos with these map correctly sorted?
  22. The Following User Says Thank You to 6mon18 For This Useful Post:
  23. #13
    Feb 2010
    WALES
    Quote Originally Posted by 6mon18 View Post
    Hi everyone,
    Of course, I have a full mappack which took me 2 years to make, label and discover full factors for.
    I'm always adding to it so looking if anyone has something new, but not seen anything for a long while.
    also Titanium has mistakes on Injection maps, I had a K4M on a Dyno and spent 2 weeks playing.
    wbr
  24. The Following User Says Thank You to shooting For This Useful Post:
    6mon18 (17th August, 2023)
  25. #14
    Aug 2023
    France
    wbr
    ok it really interests me because yes I have the titanium map but indeed some do not seem correct aps.
    Do you have 4 map of advances to ignition and 4 map of injection as for the renault clio RS 172 and 182?
    Think you can share your file?
    Thanking you
    Simon
  26. #15
    Feb 2010
    WALES
    Thanking you
    Simon
    With the time taken to make this, I won't just share it, sorry
    Knowing these addresses is only part of the map, the factors are very complex.
    There is even an offset of -22.5 on all factors.
    and Yes I know all Ignition maps for 172, 182, RS172, RS182 etc...
    wbr
  27. The Following User Says Thank You to shooting For This Useful Post:
    6mon18 (18th August, 2023)
