Results 1 to 9 of 9
    Jan 2024
    Hungary
    Default Astra H - 1.9 ECU - EDC16c9 - Flaps - EGR - DPF OFF - NEED HELP
    Hi all!
    First of all, sorry for my english.
    I want to modify my ecu.
    I need a complete walktrought, how to get started, what tools and software I need and how to do it.
    Opel Astra H - 1.9 CDTI - DTJ engine 120hp 16v
    ECU: EDC16c9 - Bosch nr. 0 281 012 123 Opel nr. -55 198 055
    I have an Kess v2 chinese clone, but i can't reading the ecu via OBDII.
    Any help would be appreciated!
    duddy's Avatar
    May 2022
    Poland
    Only bench or boot and not with this equipment
  3. The Following User Says Thank You to duddy For This Useful Post:
    rappaz (8th January, 2024)
    Jan 2024
    Hungary
    Is there no way to do what I want with this tool (kess v2 prof), even on a bench?
    rafal's Avatar
    Jul 2010
    UK - PL
    Quote Originally Posted by rappaz View Post
    if you want start play with ecu - prefer read ecu on bench with suitable tool or bdm
    trust me - less issue after
    kess not reading full on bench and not by bdm !!!
    need help
    now my goal is to buy xp-005
    who will help?
  6. The Following User Says Thank You to rafal For This Useful Post:
  7. #5
    Jan 2024
    Hungary
    K-tag or MPPS would be good for this?
  8. #6
    rafal's Avatar
    Jul 2010
    UK - PL
    k-tag + bdm frame - full
    mpps obd - partial only map area
    need help
    who will help?
  9. #7
    Jan 2024
    Hungary
    Thx,
    I've never done this before, I'm a beginner. I don't want to disassemble the ecu if I don't have to.
    Is the partial modification not enough in my case?
    EGR, flaps, dpf off?
    If I had the correct original file (stock file) that matched the hardware and software version and modified it, would it work?
  10. #8
    rafal's Avatar
    Jul 2010
    UK - PL
    Thx,
    i explained all already
    if you want risk - that's up to you
    what you will do if something will gone wrong?
    better give back car to someone who will know what to do
    need help
    who will help?
  11. #9
    Jan 2024
    Hungary
    I understand that you are recommending the safest and most secure solution, and thank you for your replies.
    I just asked to learn. Everyone started somewhere.
