Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 64
  1. #31
    Edber's Avatar
    Nov 2018
    BiH
    Quote Originally Posted by r4nd0mize View Post
    Or just not waste your time as this is incorrect in so many parameters and content so you cannot even write it to your ABS unit.
    Yes you are right and you also know that is not so easy to make correct code without additional information about car and equipments. But people trying to find these codding...and I'm just trying to help....correct code from the first try is very hard to match.
    If I help you, just press Thanks and Reputation please.
  2. #32
    Apr 2025
    Hey there,
    I currently have a 2.0 TDI Touran with 81kw/110hp
    Can you help me get the coding of the ABS/ESP unit
    Heres my autoscan:
  3. #33
    Edber's Avatar
    Nov 2018
    BiH
    Quote Originally Posted by ahmet9x View Post
    Hey there,
    Heres my autoscan:
    Try this codding...after you try....please report me to PM about results...
    0CEA6AA034252372477F060840CA2930562CC4E26002947518 62F078C202420000040212121212B235351919323200
  4. #34
    May 2018
    UE
    Default golf7 esp mk100
    Hello.
    Can you help me with long code golf 7 2014year esp mk100IPB
  5. #35
    Edber's Avatar
    Nov 2018
    BiH
    Quote Originally Posted by mati1234 View Post
    Hello.
    You can try this long codding. Please report results....
    1. 01FA62A124260975037B060041CB2580462490C06082A4F300 400078C002
    1. 01FA62A124260975037B060041CB2580462490C06082A4F200 400074C002
  6. The Following User Says Thank You to Edber For This Useful Post:
    mati1234 (8th May, 2025)
  7. #36
    May 2018
    UE
    Default mk100
    Thanks for help.
    Coding accepted first and second. I calibrated the sensors. I have errors and the esp and airbag lights on and autohold
  8. #37
    Edber's Avatar
    Nov 2018
    BiH
    Thanks for help.
    OK now try this:
    01FA62A124260975037B060041CB2580462490C06082A4F300 420074C002
    and see what errors you have...
  9. The Following User Says Thank You to Edber For This Useful Post:
  10. #38
    May 2018
    UE
    The situation is as follows:
    The airbag errors have off but the ABS errors is on.
    4254 - Internal Fault
    B200F F0 [10001001] - -
    8299 - Databus
    U1121 00 [00001001] - Missing Message
    In coding 1, ESP lights on and autohold faults
    In coding 2, only ESP lights up
    In coding 3, ESP lights on and fault: vehicle power steering system.
    I think that coding no. 2 is OK. I am afraid that the purchased ABS module is damaged and causes error 4254 - Internal Fault B200F F0
  11. #39
    Edber's Avatar
    Nov 2018
    BiH
    After you input codding number 3.....did you make basic settings of g85, g201 and other abs sensors????
    I leave you here one more code...
    01FA62A124260A75037B060041CB2980462450C0608294F200 400074C002
  12. #40
    May 2018
    UE
    Default mk100
    Sorry, but I misinterpreted the error regarding 3rd coding. It's about hill hold like in the picture.
    In coding no.4 only esp lights on and of course tire pressure but it always goes out at the end.
    What do you think, does this error 4254 - Internal Fault B200F F0 mean bad coding or module damage?
  13. #41
    May 2018
    UE
    OK, now I know everything.
    I installed the new module to the old block myself.
    Now I installed the new module and the new block (complete) and I no get error 4254 - Internal Fault B200F F0 . The Esp lights off.
    I'm going to change the whole module and bleed the brake. I'll let you know what and how
  14. The Following User Says Thank You to mati1234 For This Useful Post:
    Edber (9th May, 2025)
  15. #42
    Nov 2009
    Romania
    Hello,
    On a VW Polo 2010 I have disconnected the dashboard and the ABS control unit lost the coding.
    Can somebody calculate the coding for me?
    I have tried these codes and not worked:
    210224C24100A2E7DE5DDB16BE08FF400000 - I have calculated this according to a description.
    210224C2217200B7842D24E684D800400000 - A software calculated it (hatchback).
    510224C2217200B78A2D24E684D800400000 - A software calculated it (sedan).
    2124210084248400401100 - I have bought this code from an online service, but this seems to be too short, I have not tried it yet.
    The autoscan is attached.
    Thanks in advance.
  16. #43
    Edber's Avatar
    Nov 2018
    BiH
    Quote Originally Posted by tferenc View Post
    Hello,
    Thanks in advance.
    No, last code which you post will not work, also like others....
    Try this code....after that make basic settings for sensors....Report about results and dtc error after that
    210224E3217200B7842D24E684D800400000
  17. The Following User Says Thank You to Edber For This Useful Post:
    tferenc (10th May, 2025)
  18. #44
    Nov 2009
    Romania
    Thanks, monday I will post the results.
  19. #45
    Nov 2023
    Malta
    Hi!
    Can someone help me with the long code, GOLF V 2009, the car has TMPS, VCDS full scan is here ...
