Results 1 to 15 of 15
Thread: ISO?
    Feb 2010
    st.louis
    Exclamation ISO?
    hey guys its me tugrat i got a good question on iso downloading
    i had this game called dreamfall the longest journey any ways it was a 6 disc up load process befor i could even play the game any ways it played good nd all but i dont have the dics any more but i do still have the files for the game on my pc. My question is if i could find and download a iso file of that game would i be able to play my game without the game dics
    ps. sorry this is not in downloads and streams im not a member yet
    your friendly neighbourhood thugrat
    DK Veteran marginal's Avatar
    Feb 2010
    You need to burn the CD / DVD .iso (or whatever other image format) image files and then install the game from them.
    Est Modus in Rebus !!!
    Feb 2010
    st.louis
    what if u dont have a burner what would u do then
    Feb 2010
    There might be some software converting .iso files to .exe ones, but I can not confirm it.
    Feb 2010
    st.louis
    my guess would be to download a Virtual burner but ive never done so so i dont know how to go about it
    Feb 2010
    Why don't you look on the search engines about it?
    Apr 2010
    Default Alternate Solution
    You can also use poweriso. If you have the iso files just use that program and it will load the iso into a virtual Driver. You can also use Daemon Tools. Well from past experience, I really liked using PowerISO. Check it out and see if that solves your issues.
    Apr 2010
    You can also use WinRAR to extract the contents of the ISO image to hard drive.
    DK Veteran freck's Avatar
    Jul 2008
    Dark side of the Moon
    Quote Originally Posted by thugrat View Post
    you can change the files to iso format using img burn its a free progy just google it,then you can play the files on your pc using Daemon tools,this creates a virtual dvd rom and allows you to play your iso's from your pc....no discs required.
    Freck
    p.s. just saw post by Zanatos above.....same process really.
    V.I.P. Member cgscott's Avatar
    Jul 2008
    cmd
    Use Poweriso. It creates virtual drives which you mount the image to and it runs the same as the disk.
    No disks needed.
    This applys to all iso. Even software etc.
    Patience is a virtue.
  11. #11
    Feb 2010
    st.louis
    poweriso was my choice now can some one pleas help use the program.......on the net latly ive seen sites that try to make you join the torrents befor you can download this iso...or anything what is the best place to download videogame iso files without joining any thing
  12. #12
    Feb 2010
    st.louis
    yah i could really use someones help i still cant play my iso and i think i have the wrong iso anyway plz help me find some good iso and help me with poweriso. thanks to all
  13. #13
    Feb 2010
    Can't you write the .iso file on a virtual drive using Poweriso?
  14. #14
    Member kermitthefrog's Avatar
    Apr 2010
    get a pal that has a burner on his pc and use nero
  15. #15
    Jul 2008
    cmd
    The wrong iso?
    You can change the settings in poweriso to open all tyes of file .bin .iso etc.
    Then all you do is set number of virtual drives then right click the iso or associated file and mount it to the set drive.
    Then go into My computer and select the drive you have mounted. It will then run as a CD or DVD would when you put it in an actual drive.
