Page 1 of 4 1234 LastLast
Results 1 to 15 of 56
    V.I.P. Member ck-ok's Avatar
    Dec 2008
    nottingham
    Default neogamma r8 final
    here is the very latest neogamma r8 final with usb support
    to install put the neogamma folder that is in the apps folder in the apps folder of your sd card,then put the other neogamma folder on the root of your sd card this one contains the game hacks.
    there is also a full channel wad, but you will still need the neogamma folder with the game hacks on the root of your sd card
    if you have any problems there is a readme file
    Jun 2008
    Thanks - I'm still on RC8 at the mo - can I assume that this version is stable and smooth?
    Dec 2008
    nottingham
    Quote Originally Posted by middlewingnut View Post
    yeah no problems
    May 2010
    Default Been meaning to try this
    Been having some issues with uLoader.
    I'll give this a shot.
    I'll post how it goes.
    May 2010
    thanks does anyone if r9 is any good?
    Dec 2008
    nottingham
    Quote Originally Posted by apezelet View Post
    as far as i know r9 is no different to r8 except improved game cube playback
    Jun 2010
    Default Nice
    Hopefully this will enable smoother playback of some backups.
    Dec 2008
    nottingham
    Quote Originally Posted by Zartonis View Post
    if you want smoother play use a usb /hdd as backup discs only play at x3 speed instead of x6
    Jun 2010
    Will this version play the latest new released games for the Wii?
    Dec 2008
    nottingham
    Quote Originally Posted by swebstar1 View Post
    it will help,you might need to update your ios 249 aswell
  11. #11
    Jun 2010
    Thanks a lot! Will this play POP: The forgotten Sands?
  12. #12
    Jun 2010
    Thanks goooood job
    but is it work with HD
  13. #13
    Dec 2008
    nottingham
    Quote Originally Posted by lee2000 View Post
    Thanks goooood job
    yes as hd support
  14. #14
    Nov 2008
    Bristol
    can i put this as a channel on the wii or do i have to keep going through hb
  15. #15
    Jul 2010
    how to upgrade from neogamma v8 beta ?? any different ?
