Results 1 to 9 of 9
    Aug 2009
    Default nedd help for coding new dash A3
    hello all dk today i have replace dash on audi A3 8P YEAR 2004
    i have learn new key and car star but in dash bord show safe
    how make a adaptation
    i scan unit 25 immobilizer i have :
    01179 incorect programing
    permanent error
    UNIT STEERING ASSISTANCE :
    02546 sreering limit stop statut permanent error
    missig data or wrong setting adaptation
    00778 steering angle sensor
    02441 yellow malfonction in instrument cluster
    statut premanent error
    UNIT ABS :
    00778 steering angle sensor statut permant error
    missing data or wrong setting adaptation
    THANKS FOR YOUR HELLP
    00810 sensor 1/2 for break pressure statut error
    01423 lateral acceleration sensor G200 permanent error
    00778 steering angle sensor statut premanent error
    z786's Avatar
    Aug 2009
    10 Steps Ahead of You
    have u still got original dash?
    "I always tell the truth. Even when I lie"
    "We Taking Over, One City At A Time"
    Aug 2009
    Quote Originally Posted by z786 View Post
    odl dash is defect there is an other dashbord but not new
    ION CRISTI's Avatar
    Jun 2010
    ROMANIA
    big problem. first you need to remove all data from the new dashboard, delete old vin. no need appear safe display, another memory the key
    z786's Avatar
    Aug 2009
    if you have original dash, can you log into 17 instruments?
    Aug 2009
    Quote Originally Posted by ION CRISTI View Post
    i have commander original i have go unit 17 instrument
    try to change vin softaware say me not vin in this unit
    but on the unit 25 immo there is another vin i try change
    it say not avaible
    i think i can make on read writ immo data
    Aug 2009
    i have old dash original but is defect i have probleme on power in switch on when try connect wit unit by diagnose
    there is no comunication
    z786's Avatar
    Aug 2009
    any chance you can give me a VCDS autoscan txt file off the car?
    i might be able to give you the correct coding
    swingman26's Avatar
    Mar 2010
    france 26
    hello, how i can do for remove vin... in new used dashboard a3 2004 ?
