Page 1 of 2 12 LastLast
Results 1 to 15 of 17
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    Default CAN ANYONE FIND ME A GEARBOX CODE FOR A VW
    heres the chassis number WVWZZZ1HPW747301 is a golf auto , m8 needs a box for it ,, cheers lads
    Liteace's Avatar
    Mar 2009
    On a rock
    The g\box code is on the sticker in the boot, check the chassis number youve got a digit missing
    Mar 2008
    birmingham
    Quote Originally Posted by Liteace View Post
    cheers l will get him to text number again
    Liteace's Avatar
    Mar 2009
    On a rock
    Tell him to lift boot mat and there should be a sticker there near spare wheel
    Meat-Head's Avatar
    Not knowing the year, but Austin Montego's used
    VW Gulf gearboxes
    Liteace's Avatar
    Mar 2009
    On a rock
    Quote Originally Posted by Meat-Head View Post
    VW Gulf gearboxes
    there cant be any of them left on the roads, can there ? an automatic Austin Montego what could be worse
    Sep 2008
    2 of them
    Mar 2008
    birmingham
    WVWZZZ1HZPW747301
    here the right chassis number m8 ,, theres no label in the boot its gone
    cheers
    its ok my etka worked . its meant to be an cbx box but the picture isnt right ?
    the one he needs has a dip stick
    Sep 2009
    hello , if you want to repair ...i can give you some pictures with parts ( for repairing) .... if is helpfull
    Liteace's Avatar
    Mar 2009
    On a rock
    Quote Originally Posted by smirnoff_rules View Post
    WVWZZZ1HZPW747301
    cheers
    Did you get it sorted ? the "cbx" box is for the syncro, problem is for 4 speed auto you have:
    CHF, AOG, CHG, AMM, CCA + about 20 others, the 1st pic in your attached thumbnails, that box does have a dipstick you can see the dip stick tube on the end of the box and the top of the dipstick just by the oil cooler on the top of the box, problem is, is getting the correct final drive with all those different variations
  11. #11
    Cant help with a gearbox i'm afraid but if you let me know the problems ,i might be able to advise an economic repair . ie the target ring for the speed sensor coming loose was a very common fault.
  12. #12
    Mar 2008
    birmingham
    his problem was the autobox oil cooler was leaking and mixed water and gearbox oil and now has lost reverse it trys to move for a second , its stuck on his drive but trys to move forward ok ,,
    l was going to flush and refill but wasnt sure if its to late
  13. #13
    To late : over the years i have seen transmissions filled with axle oil ,brake fluid ,you name it , but water is the worst of all. after the break when we are all back to work i will put out a few feelers and let you know.
  14. #14
    Meat-Head's Avatar
    Quote Originally Posted by autotrans View Post
    but water is the worst of all. .
    So if you was REALLY bored, could you not do anything with it - eg strip it, leave in diesel, get it clean and away?
    Just the metal case, came out the ground with coal and soil, the gearbox oil, also came out the ground?
  15. #15
    Most transmissions run 100 degrees C + so water turns to steam and literally strips bonded pistons & seals and any friction plates so everthing runs metal to metal even
    lock up converters. that's without the rust problem in
    needle rollers, planet gears valves ect . the main case is the one thing that normally survives ,with an old vehicle
    it is just simple economics
