Dreambox Connections
  • vergil7
    • 29
    How do you connect the Dreambox 500s to a dvd or video to copy programmes when there is only one scart connector on this receiver .
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    You need to use the composite out connections (yellow for video, red/white for stero audio).
    Most dreamboxes come with a composite cable in the box.
    You can also get a composite to scart cable which would make it easier.
    SCART TO COMPOSITE VIDEO 3 PHONO RCA 5M CABLE on eBay, also, SCART Cables, Accessories, Consumer Electronics (end time 09-Jan-09 20:35:51 GMT)
    • CharismaPro
      • Oct 2008
      • 51
      most dvd recorders have 2 scarts...go to the dvd, passthru to tv...your...this means you can simply hit record and its done...also you can view on the tv...i connect the dreambox to this way and use the hdmi output into the tv from the dvd.
      • Dazmeister
        • 43
        This is why we stream to NAS drives or pc (500c) as its a lot less hassle.
