dreamnetcast
  • dunryc
    • 15
    dreamnetcast
    can any one give me a heads up with the dreamnetcast pulgin ive sucsessfully installed it on an enigma image but can seem to set it up on neutrino Dream+ ultra 0.9b any one got any ideas
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    There should be 3 files.
    dreamnetcast.cfg -> /var/tuxbox/plugins
    dreamnetcast.so -> /var/tuxbox/plugins
    stations.xml -> /var/etc
    CHMOD 755 the .so file after copying it to the box.
    Reboot the box after copying files and it should be accessible from the plugins menu on the image.
    Edit the stations.xml file with your own radio stations if you want.
    • dunryc
      • 15
      thats where ive place the files but mine seem to be called DreamNetcastDBB.cfg etc any pointers to where i can find one without the DBB at the end i think it may be enigma only
      • Devilfish
        Administrator
        • Feb 2008
        • 7872
        Try here...
        Tuxbox Commander Useful for editing files on your dreambox. Dream Netcast Internet Radio Listen to internet radio on your dreambox. Edit the /var/etc/stations.xml file to add new radio stations. Dream Weather X Weather information DB Switch If you have two dreambox receivers in the same room you can use this to
        The .tar.bz files can be opened with WinRar. Just copy the files in the folders to their respected folders on the box. If it doesn't have an 'Uninstall' folder, don't worry about it.
        • dunryc
          • 15
          cheers for the info im linux only so the bunzips dont worry me as i say ive had this running on enigma but i much prefer the neutrino interface !!
          • Devilfish
            Administrator
            • Feb 2008
            • 7872
            I must admit, I've never had it running on neutrino. I prefer enigma for the dreambox and neutrino for my dbox2.
            EDIT:
            Just thought....it might only be fore enigma because if you look at the config file it says...
            name=DreamNetcast
            desc=
            depend=
            type=2
            needfb=0
            needrc=0
            needlcd=0
            enigmaplugin=1
            • ntountasgeo
              • Sep 2012
              can i put my own radio stations?
              • ntountasgeo
                • Sep 2012
                question
